I have a front loader (SAMSUNG j845) that has stoped working its like its frozen all buttons light up but i cant move dial and cant press start, even the power button does not work (have to switch it off from the wall) is there a reset button, ive turned it off and on at power point and pulled the power cord out and left over night but no good please help.
  • leeawc Jul 14, 2009
    no, there are no error codes displayed...
    This happened after a brief power outage and when I came home, the machine was still off. when the power came back on.. i had to switch the washer back on.
    The washer did power (and still can) on but it is constantly stuck at one setting and no buttons work. I mean you can press them and turn the knobs but nothing changes (including the power button). I had to switch it off at the wall and waited 5 minutes till the door unlocked to get the wet clothes out. (must have happened during the spin cycle)
    But I will try and have a look at the belt later to see if that may be it.
  • Washing Mach... Master
  • 4,806 Answers
The power outage has probably caused the machine to act a little weird and stick on a cycle. As far as i know there is no reset button on that model machine and the fact that there is no error code indicates that the machine just needs to be unplugged from the wall for around an hour or so for the components to reset themselves.
While you are waiting its a good idea to reset your surge protectors if you have any.
Regards.
Posted on Jul 14, 2009
  • 3,230 Answers
First of all i like to know is there any error code on the display?
It seems like there is a belt was broken. You can verify this by pulling the washer away from the wall and tipping it back to look underneith.
Good Luck!!
Thanks
We have a samsung j845 top loader and a de error came up while it was washing and i cant even drain the clothes
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault.
The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board.
If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Aug 30, 2010 | Samsung WF337AA Front Load Washer
Our samsung j845 front loader wont drain we have pulled every hose off and flushed them all out we have drained it and still nothing everything still sounds as if its working properly but it just wont...
I have a Samsung J845 front loader washing machine, A few weeks ago, no water would go into the machine, so replaced the broken solenoid. Now the water never stops going into the machine ??? The solenoid is working but not getting electrically turned off. When I pull the terminal from the solenoid the water stops. What has gone wrong now???
Jun 04, 2010 | Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
Help remove and replace the diaphragm on my samsung J845
The front loader machine should be done by a appliance dealer because this is a diffuclt job and need a lot of patience if you do it. Hope this might help.
Jun 02, 2009 | Samsung WF337AA Front Load Washer
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Samsung electronics clothes washer model j845
If you have a face icon lit up the child lock is on, press and hold spin and rinse buttons until it goes off
Apr 26, 2008 | Washing Machines
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
