Question about Canon NP 6050 Copier
E004 i have code e004 i go to *4* i find no error.will u help me with this.the machine still indicate code e004
  • Canon Expert
  • 1,326 Answers
A E004 deals with the fuser unit. Have you looked at the Thermister or the thermal fuse or the fixing lamps? I would say that most likely you have a blown or shorted thermister. One of the wires may have come off the pcb.. I you want to see the error code, I believe it is under *6* counters... *4* is for resetting the code
Posted on Jul 14, 2009
  • 4 Answers
Ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, waiting for your vote.
Posted on Apr 25, 2013
We are facing error code e004 Scanners in Konica Minolta c224, please help us if you have any solution.
Try to upgrade the firmware of the mashine to c224e. Remember to use USB device max 2gb volume
Jan 11, 2015 | Konica Minolta Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Casio ce6000 error code e004
That means it is having trouble with the memory backup. Don't unplug the machine as it is about to lose all programming and sales data. Has this machine been turned off for a long period of time? When was the battery last replaced?
Jun 25, 2013 | Casio Parts Cash Register PC Desktop
Canon np 7161 E004 error
try your best, kibokoyao waiting for your vote.
Apr 26, 2012 | Office Equipment & Supplies
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
#7 PRINTER > #4 PRINTER RESET > YES = (*).
sonsunny
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
E000 IS DISPLAYED IN THE MACHINE
E000:
The main thermistor reading does not reach 40ºC 14 sec after the fixing
heater goes ON. (fixing low temperature error).
First you need to try reset the error code and the procedure for that is:
SERVICE MODE entry: MENU and #
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and turn
off and then on the power switch to clear the memory: #7 PRINTER>#4
PRINTER RESET>YES=(*).
If the error is still present after clearing, you need to dismantle fixing unit and check with universal voltmeter the lamp, by putting the DVM to buzzer mode and each ends of dvm probes put on ends of lamp, if it buzzs that means that there is connection and lamp is OK, so you need to focuse on thermistors and thermofuses or ... call service.
Hope that helps!
Aug 19, 2010 | Canon iR 1600 Laser Photo Printer
Canon NP 2120 Copier that is giving Error Code E004 on power up. Any solutions?
E004 CODE IS FOR FIXING UNIT TEMPERATURE IS NOT REACHED THE SPECIFIED RANGE. CHECK HEATER LAMP, THERMISTER, THERMOSTAT.
Dec 18, 2009 | Office Equipment & Supplies
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
Codes eoo4
this error means that there is problem with the fixing unit lamps ,thermistor and thermal fuse a fixing error reset is needed but if the machine shuts off automatically ,means there is an open AC supply to the heater.
Jul 15, 2009 | Canon NP 6551 Black and White Copier
Canon NP 6050 Copier Logo
632 people viewed this question
old marine
old marine
