Question about HP iPAQ RX3715 Pocket PC
Power switch not working
The powr switch on my ipaq does not work
Same problem for me, i've noticed that it only works when the charger is plugged in !!! Please help!!!!
Posted on Feb 26, 2008
Why aren't my powr windows working
Check the fuse for the Electric windows, if thats okay check for corrosion on the wires going to the motor and switch. Test the switch for continuity to see if that works . If all else fails you culd have a break in the wiring loom or a damaged motor.
Nov 16, 2011 | Cars & Trucks
Hi. 91 bronco no stoplites or hazards.powr out of fuse box no powr at sockets. tail lites wurk fine. i tried 2 run makshift grd but no lck.directnls r fin and hazards wurk in front, its like both rh and lh...
heck power on both sides of brake light switch with pedal depressed.if power on 1 side only replace brake light switch.if no power to brake light switch check turn signal switch.
Jan 02, 2010 | 1991 Ford Bronco
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Touch pad not working on my ipaq hx4700
open the device and check the componets are not shorting out, when you droped it, with that much force you may of bent the leads inside or broken, if it bent you can fix it but you broke it than it is time to buy a new one, check the power source for that switch make sure it is okay.
you may of knocked something out of alinement.
Mar 03, 2009 | HP (FA302AAC3) for IPAQ Rz1700, Hx4700...
HP ipaq 6315 No power
Hello i'd be happy to help :-). Since you said that you bought a new battery and it still didn't work. I am guessing that you might have charged you Ipaq by pulling it into a regular wall outlet . This is bad because that outlet could send to much electricity into the Ipaq and can kill it. That might be the problem why your Ipaq is not working... I would recommend for you to call HP and see if you can return your Ipaq to them and see if they can send you a new one.
Jun 18, 2008 | HP iPAQ H2210 Pocket PC
How to switch off my hp ipaq
On most HP pocket PC's, holding the power button momentarily will turn it off.
If you hold it too long, it will only turn off the backlight, but the unit will remain on.
Apr 27, 2008 | HP iPAQ RX3715 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
