2001 Hyundai Santa Fe Logo
T
Tony Robbins Posted on Nov 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would be wrong when my car has gas, but no spark?
Santa Fe won't start. Has new plugs, plug wires and coils. It is getting gas, but not fire/spark.
Nicola Conroy
Level 3:
  • Hyundai Master 1,428 Answers
  • Posted on Dec 20, 2016
 Nicola Conroy
Hyundai Master
Level 3:
Answers
1428
Questions
Helped
715174
Points
3702
Have you tried compression test
Claude Kayser
Level 3:
Top Expert:
  • Hyundai Master 9,098 Answers
  • Posted on Nov 26, 2015
Claude Kayser
Hyundai Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067398
Points
28436
2001 Sante Fe Won't Start, Cranks But No Spark. - Hyundai Forums ...
www.hyundai-forums.com/...santa-fe/112601-2001-sante-fe-won-t-start-...
Jul 23, 2010 - 10 posts - ‎3 authors I have a 2001 Hyundai Sante Fe that died on me while driving down my street. ... Thecar has many other unrelated problems and I am not sure I want to ... may be causing my two cylinder no spark and alleged fuel problem? 2006 Santa Fe 2.4 Engine swap-no spark
Sep 24, 2012
No Start 2.4L Engine 2004 Manual
Nov 26, 2011
Good Crank/Have Fuel pressure/NO IGNITION
Oct 9, 2011
Car Cranks But Will Not Start
Jan 16, 2008
More results from www.hyundai-forums.com
Engine cranks but won't start.What should I do. - YouTube
? 9:37
https://www.youtube.com/watch?v=jsQcLya1YLQ
Jan 24, 2014 - Uploaded by jimthecarguy
No Start Cranks Ok No Injection Pulse 2002 Hyundai Accent Easy Step By Step ... and car cut off, but would not restart. it sounds like it is starving for fuel. ... hi nice video man . i have no sparkno fuel .u think its the main? it was ...
Cylinder 3 misfire on 2001 Hyundai Santa Fe
sometimes the fuel injector can be out of range but this would give a trouble code.
then check spark plug to see if it is wet or fouled.
check plug wire for external sparks.
last check the coil pack.
2003 Santa Fe V 6 miss firing with New plugs and wires
Got a check engine light? Get the codes read to find out if the misfires are on all cylinders or just 1. Could be ign coil, bad crank or cam sensor, or a valve issue
I have a 2006 Hyndai santa fe and it stalls out or sputters when idleing.
It sounds like a cam Or crank sensor problem (which controls the coils) I can only advise u from here to find a new CAR GUY. Good luck
Where does the spark come from on a 2002 santa fe 4 cyl.
On your Santa Fe, each spark plug has it's own "coil". the computer sends a signal to the coil at the precise moment that it needs to provide power for the spark plug.
How do you get to the spark plugs 2005 hyundia santa fe
There's a plastic cover on the valve cover, remove small bolt's holding cover, under cover will be two coil pack, and a total of 4 spark plug wire's, remove small bolts to coil pack, will have two bolts to each coil pack, disconnect elec. harness, remove coil pack, spark plugs will be in there.
1helpful
Changing spark plugs
You most likely have a big cover over the engine that is covering everything up. If you can get that off (sorry, I've never removed one) you should be able to see the plug wires/coil on plugs, whichever the vehicle has. 4 or either 6 depending on the number of cylinders. You may just see black rubber looking caps. Plugs are under them.
Spark plugs and wires on 2003 santa fe
why would you fix a problem that is not there.if it is fine then enjoy it.plugleads only get changed if faulty.
3helpful
2answers
2001 Hyundai Santa Fe Ignition coils & EGR Valve
Well I went ahead and took a go at changing the coils, plugs and wires yesterday. It literally took maybe 15 minutes and my hands didn't even get dirty. This is something that the auto place wanted to charge me 650 to do. I spent 200 on parts. I didn't realize the coils were the things sitting on top of the spark plugs. I think my 4 year old could've done it. All I had to do was unbolt the coils detach the wires and then replace. It was too simple.
1helpful
2answers
2.4l santa fe spark plug location
there are 2 covers that are over the plugs the first is the big silver and black cover that has four
10mm bolts remove them and then there is a small black cover that is inbetween the two humps on the valve cover i think that there 6 bolts that holdthat down remove this and the coils and plug wires are visable
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
