Question about ASUS VW222U Monitor
There is a pop up on my screen that sais: "Enable OverDrive" and I can choose YES or NO, but non of the buttons are working, and I can't shutdown my monitor. maybe its because there was a lot electrical power interruptions and then my monitor was shut down badly.
  • 2 more comments
  • Noam K Jul 14, 2009
    we are talking about ASUS not ATI, but thanks anyway.
    Well, now I know why is it happening,
    The monitor thinks the "menu" button is still pressed.
    after 6 seconds of pressing this button, it shows "Enable OverDrive" pop up.
    I don't know the solution.
    Can someone help? please?
    The problem is that this Enable OverDrive pop up pops every time, and that's because the Menu button is still pressed, I don't have to press it and that's the problem, I want the Menu button to not be pressed.
    Do you mean, broken from inside? because its looks o.k from outside. and it started suddenly, I didn't touched this button.
Hello... after a day with the same problem... I finished my calm... and slapped with my fingers in the buttons of my monitor... and they started to work... I think that was a very stupid solution, but in my case it work fine! hope that fix your problem too :)
Posted on Nov 22, 2010
    President:
  • 627 Answers
  • 1 more comment
  • Robert Nyilas
    Robert Nyilas Jul 14, 2009
    Sorry
    try this:
    You can try disable/enable ‘Overdrive’ by holding the Menu button for eight seconds and highlight the selection you want.
  • Robert Nyilas
    i think the button is broken, you must change it
  • Robert Nyilas
    it makes permanent contact inside. it is a miniswitch
How do I get this pop up that says enable overdrive yes or no of my screen it wont go away cheers
Run a good quality anti malware programme and be careful when downloading for odd things like this in the future.
Sep 24, 2014 | ASUS Computers & Internet
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Turned it on and everythink has frozen. the screen sais philips and non of the buttons are working.
It may have only 'locked up;' pull the AC plug and ignore it overnight. This may not help but won't hurt anything and if it is a lockup, it may clear itself.
Mar 25, 2011 | Audio Players & Recorders
The Enable Overdrive menu pops up on the screen when i turn it on and it wont go away. ive checked to see no buttons are stuck in aswell but it will not go away
are you sure it isnt software installed on your pc that is displaying the overdrive menu . Check to see if you have it installed, as as far i can recall there is no overdrive program for monitors. They are used to overclock the cpu of your computer
If this has helped you please give feedback by voting
Feb 23, 2011 | ASUS MW221U LCD Monitor
I cannot play youtube video, I just get a black sreen
Follow the below steps
1. Right-click in the standard streaming video window (non-full
screen).
2. Choose 'Settings...' from the Flash Player's pop-up menu.
3. Uncheck the 'Enable Hardware Acceleration'
4. Click 'Close'.
Oct 30, 2010 | Computers & Internet
Wifi button not working
It is better to give your lap nearest service center..they will help you to solve this problem.
Nov 05, 2009 | Acer Aspire 7720-6844 Notebook
I dont know how to dowload java on pSP
This is how you enable JavaScript on the PSP, for use while in the internet browser:
  1. Step 1 Choose "Tools" on the PSP home screen by pressing the "X" button.
  2. Step 2 Choose "Settings."
  3. Step 3 Select "JavaScript" from the "Settings" list.
  4. Step 4 Choose "Enable JavaScript" and then select "Yes." Press the "O" button to close the "Settings" screen and finish the procedure.
There are a couple of ports for running JAVA on the psp, in various stages of development. BlueKVM is one of them, and you can see it here and here. Of course, this is called homebrew programming, and will only run on psp's running custom firmware. Sony does not officially have support for java on the psp.
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
Enable Overdrive
yes, the problem is off by itself, i did nothing:) thanks for your interest;)
Aug 25, 2009 | ASUS VW222U Monitor
I choose a video clip , the page shows up then only blank or black screen shows up
It may be cause of different reasons, at first you should find the source of problem.Maybe your OS, maybe your Browser, Your connection, Your Flash player, and maybe youtube! So, at first I suggest you to install latest version of flash player from adobe website, Also check that by other browsers like IE, Firefox, Safari, Opera and ... .
But
check this way:
1. Right-click in the standard youtube video window (non-full screen). 2. Choose 'Settings...' from the Flash Player's pop-up menu. 3. Uncheck the 'Enable Hardware Acceleration' 4. Click 'Close'.
Full-screen should now work, or at least it did for me. Some kind of Flash incompatibility with latest Firefox build, it would seem. I am running vista, so maybe that has something to do with it, as well.
Source: http://oracleappstechnology.blogspot.com/2008/10/youtube-full-screen-shows-blank.html
Mar 15, 2009 | YouTube Videos
Enable overdrive on screen
у меня на екране показывает Enable over driver (Yes no) ничего немогу зделать показывает по центру. Ето сообщение невозможно выключить. помогите кто сможет.
Windows 7 ultimete 64-x
nvidia Geforse 9600GT
intel core2 duo CPU E8200
2.66GHz
2.67GHz
RAM 4,0GB
[URL=http://fastpic.ru/][IMG]http://i13.fastpic.ru/big/2011/0109/69/6b3db7b0dbe4318765b52ad3b6a5ca69.jpg[/IMG][/URL]
Feb 03, 2009 | ASUS VW222U Monitor
ASUS VW222U Monitor Logo
2,851 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
