Question about Sony KE-MX42A1 Television
My sony ke-mx42a1 shuts down and the stanby
My sony ke-mx42a1 shuts down and the standby indicator blinks 4 times.
What can I do to solve the problem?
    President:
  • 1,077 Answers
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Sony. Ke mx42a1 problam is that red light 9 bilinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 05, 2015 | Televison & Video
Sony ke mx42a1 problam is that red light 9 bilink
Dec 05, 2015 | Sony Televison & Video
Klv 32s200a
There are two things you can try. Press "Sleep" until you see "off" appears. If this doesn't fix the problem, go to the "Eco" settings and set "Power Saving" to "Off", set "Idle TV Standby" to off, and "Auto Shut Off" to "off". I hope this works for you.
Sep 20, 2013 | Televison & Video
Sony wont turn on but will blink in stanby
How many times do this standby light blinks? Count it. These are blinking codes, and are fault indications. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. To get more information about blinking codes, check this site. It has details to many brand TVs' blinking codes, including Sony. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 09, 2013 | Sony FD Trinitron WEGA KV-36HS510 36" TV
How solve my problem w/ lcd sony bravia 32in raster 3x show then goes to stanby the blinks
I will need the model number of the Sony and also how many times does the light blink? Thats an error code so the number of blinks will be linked to a specific area of the TV having an issue.
Feb 10, 2013 | Televison & Video
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Tv stay always standby
how many times does the indicator blinking?.
Oct 10, 2012 | Sony Televison & Video
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia goes into standby mode blinks 13 times in sequence
standby light flashing is an indication that tv needs service. it prevents the tv from further damage. go to www.eservice.sony.com to check service options
Oct 01, 2010 | Televison & Video
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
