Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
No-ip.com how do i get sbg900 to work with no-ip.com without computer
  • zel-jko Nov 17, 2007
    i am trying to get permanent ip so that i can use dreambox as server
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
What exactly are you trying to do?
Posted on Nov 17, 2007
Motorola SBG900 NAT problem.
Nat can be turned off in the sbg900, but not recommended, as it also shuts down the dhcp, which is responsible for providing ip addresses to you PC,xbox etc.. I do not believe there is a work around. Nat sometimes limits certain games, but I have not found any games other than COD that I have ever had problems with. bottom line, if you need to disable nat, then you will need to plug directly into modem.
May 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
I don't remember the password for my sbg900 motorola router and i need to connect one of my laptops to the network. How do I get the security key. I read another blog that mentioned pressing the reset...
Disconnect the Coax cable from the modem and restart it. Once the "Receive" light begins flashing reboot your computer. If the modem and the computer are communicating, the computer will get a 192.168.100.11 IP address (192.168.0.x with the SBG900) from the cable modem. Shut down your computer. Connect the Coax cable to the cable modem, restart it, and wait for the modem to sync up with the cable company. Once the modem is in sync (Power, Receive, Send, On-line are all illuminated) restart the computer. Once the computer has restarted check the IP address. The computer should have a valid IP address from the cable company. Computers attached to the SBG900 will always get a private (192.168.0.x) address regardless of whether or not the SBG900 is registered on the cable system.
Dec 01, 2009 | Motorola Computers & Internet
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 WEP password problem - MAC OS X
  1. Try the ethernet cable, but also configure it manually by setting the gateway as 192.168.0.1 and the IP to 192.168.0.2
  2. Then enter normally and reconfigure it.
Optionally, try holding the reset button for 20s and access through wireless if you want.
May 27, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Online problem with motorola SBG900
hardwire the modem with the acer computer and shut both the modem and the computer down..then turn on the modem ..wait for a minute and then turn on the computer..just check whether the status still says local or not.....remember this is the first step..if it doesnt work,,keep me infmd,,i will be back with u
Mar 16, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900-SiS191 Ethernet Controller
Setup your IP addresses correctly by checking available IP addies in router.
You will have to know your router addie and your available wireless addies (in router). For this you need to enter router configuration (read manual).
Open network properties, tcp/ip properties, check "use following ip addie and enter something like 192.168.1.5 depending on what your router is setup as available.
Enter same subnet as your router.
Enter DNS server addies from you ISP.
Feb 02, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't connect to the internet wirelessly
Well, to avoid confusion, I'd start by doing a factory reset. Insert the straightened end of a paperclip into the reset hole and power up the device to do this. From there, the device should begin broadcasting the default wireless network with the name (SSID) of "Motorola." The DHCP server should also be enabled and if your computer is configured to receive an automatically assigned IP address your wireless network interface should pick up an IP. The security for the "Motorola" network is disabled by default.
Basic troubleshooting from there would be to try to see if you can connect your wireless computer to another wireless network that is know to be working well. Either buy and return another wireless access point or router from a retailer or head to a Starbucks or other establishment that offers free wireless. If the wireless computer is hooking up nicely with the secondary wireless network, you can refocus on the SBG900 as the likely source of the problem.
If after attempting the aforementioned procedures you find that the wireless computer continues to fail to connect to the SBG900 you might have to consider that you have a faulty device. At that point I would consider consulting the manufacturer's documentation.
Apr 05, 2008 | Arris SURFboard SBG900 802.11g/b...
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
53 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
