Question about Brother Office Equipment & Supplies
Why cant i print with just a black ink cartridge Do I need all color cartridges.
  • 39 Answers
Sadly, with lots of printers, yes is the answer to that question.
Posted on Jul 14, 2009
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Why two black ink cartridges?
The larger of the two cartridges is used for text only. The smaller is used for color printing. Its purpose is to eliminate the need for a "Processed" black (black being mader by the color inks).\
Don
May 30, 2009 | Canon MP610 Photo All-In-One Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
When I want to print using the photo or black ink cartridges, my printer uses the tricolour cartridge. If I take the tri colour cartridge out, the printer alerts that there is a cartridge missing and still...
If what you are trying to print is a black in white image then you cant print that when you dont have the other colors installed. The reason is because your image/photo has shades of gray, and for the printer to produce gray, it needs the other colors as well. It needs colors to get the light black or gray shades of the photo....
If however, you are trying to print text only, the printer should be using the black cartridge and not the other colors... I believe that there should be an option in the printers preferences to select black ink only... look for it under advance tab...
hope this helps
Sep 05, 2008 | HP Office Equipment & Supplies
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
42 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
