My front panel headphone& mic connecting pcb have only 7 slots and the cable is named as 1)LINE OUT FR,2)LINE OUT RR,3)LINE OUT FL,4)LINE OUT RL,5)MIC IN(R),6)GROUND,7)MIC POWER(L) how can it connect to ASUS M2N-MX SE PLUS mother board
    Sergeant:
  • 449 Answers
FR stands for Front Right, FL for Front Left, RR for Rear Right and RL for rear left. These are speakers connections. You need a convertr cable to connect your headphones with your PC. After getting cable, connect it with FR and FL or RR and RL pair. Your headphone will be working. Similarly get the cabl for Mono to Stereo Mic and you can connect your mic too. (ehteshamhusain@gmail.com)
Posted on Jul 17, 2009
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
Car Audio - mixed ohm speakes - best setup
Here is the link how the speakers are suppose to be connected.
http://www.fixya.com/Uploads/images/94A2E8C.jpg
You notice how they hook it up the left connections are your full range or hi frequency speakers and the switch is on for HPF (High pass Filter meaning only high frequency is being passed thru)
The right connections are connected to subs and the switch is on for LPF (Low pass Filter meaning only low frequency is being passed thru)
If you turn off these switches to off the its FULL RANGE all frequencies will pass thru.
The single output of the radio is probably for a subwoofer output but since your using the amp to power speakers too Its useless because your sending only low frequencies to the amp which will make any speakers connected to the amp sound horrible due too all the highs and mids will be filtered out.
STEP 1. 2 4ohm speakers depending where you put them Front or back. Hook these speakers up to the Radio's speaker wires coming out of the radio harness. You can also call them Hi level output wires FR & FL wires if positioning them in the Front. Hook them to the RL or RR if positioning them in the Back. What ever wires you dont use tape them SEPARATELY . DO NOT TAPE THEM TOGETHER and cause them to touch each other it will short out the radio and you will hear no sound.
STEP 2. Ok get 4 same length speaker wires and cut them long enough to go too the amp. Now these speaker wires will only send the FULL RANGE frequency signals to your amp. So note with a paper and pen how your connecting each speaker wire. I would tape one wire with black tape to remember this is the FR right, 2 tape FR left, 3 tape BK right, 4 tape Bk left. And I would make the copper thread of the wire positive and silver thread of the wire negative (very important so that your in phase and it will sound awesome) mixing up the positive and negatives will give you a tinney sound and it horrible to hear .
STEP 3 connect these 4 speaker wires to the High level out speaker wires coming out of the radio. The wires that are already connected to the 2 4ohm speakers go ahead and splice into them and the ones you didnt use connect to the remaining 2/4 speakers. REMEMBER OR NOTE THE CONNECTIONS cause you have to connect the right sequence and right polarity + & - to the HI Level input of the AMP. You will not use any RCA'S from the radio to the amp anymore. Since your radio dont have any Front & Rear output coming from the back of the radio. (YOU CANNOT USE BOTH RCA INPUT & HI LEVEL INPUT OF THE AMP ITS 1 or the other OR YOU WILL BURN OUT THE AMP AND DAMAGE THE RADIO)
STEP 4. Now connect your 2 6ohm speakers of your front left and back left together in parallel and your 2 6ohm speakers of your front right and back right together in parallel. Look at the diagram hook it on the left connections as in the picture of the front left speaker(but your connecting two 6ohms valued at 3ohms when in parallel and the amp can handle 2ohms so its safe) Do the same connection for your two right speakers as shown in the diagram of the Front right speaker. SWITCH THE HPF to OFF so that you get full range out of your speakers. Mid range is 70% of your music if you turn it ON you are only getting the high frequencies and it will sound awful.
STEP 5. This is the final connection Your 6 ohm sub is very bad for this amp. For example if you bridge it off of the last two channels the amp may double the power. If each channel is 100 watts and you connect the positive to one channels positive and connect the negative to the others channel negative(presuming its bridgeable) On a regular 4ohm sub it will be getting 200 Watts of power which is an average thump. Now you put a 6 ohm sub it will be weak and it will be getting around 130Watts. To make it worse if this 4 Channel amp is not bridgeable you can only connect it to 1 channel and the output will be around 70 WATTS causing distortion due to lack of power. If you still connect the sub be sure the switch is ON.
Good luck cause this the best connection you can do anything different and I'm sorry it will sound even worse. I am a master installer and have done this for 12 yrs. The higher the ohms the worse the sound gets cause less power. Thats why car speakers are 4ohms and home speakers are 6 ohms or higher cause they have a bigger amplifier to power and 120volts AC current. A car only has a 12Volt DC current powering the amp.
Apr 06, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
From cabinet front panel how can i connect to audio in mb. In cabinet I have cables with - lineout fl-rl, fr-rr, mic-gnd,mic power for DG41
Get the motherboard manual. The manual should have the motherboard connections.
If this does not answer your questions please post and give a more detailed explanation as to what you are trying to do.
Jun 06, 2009 | Intel DG31PR Motherboard
FRONT PANEL AUDIO HEADER PINOUTS CONFIGURATION HELP
It really is your choice. You can use the AC'97 or HD but not both. Follow the wiring for the choice you select. Personally I'd go with the AC'97 setup as alot of games have issue with the Realtek driver. Hope this helps.
May 02, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Computers & Internet Logo
387 people viewed this question
David Payne
David Payne
