Question about HP Compaq Presario CQ60Z Notebook
My laptop touchpad scroll button is no longer working
    Sergeant:
  • 361 Answers
There is two case one physical damage or softere damage. u can repair softwere problem. if you have bord cd there is touch pad softwere. right mouse click on my computer click hardwere look softwere stall or not stall . if not stall. click on river ....click....click . you can stall softwere. if physical damage cnotat t o tech.( it is better to re in stall once time if softwere problem)
Posted on Jul 14, 2009
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I had to get a reinstall done on my laptop. When I got it home the scroll on the mouse pad no longer worked. How do I get the scroll to work again?
Hi
Have you tried all the windows updates because that may offer you a update for the touchpad
if not you may have to go to the manufacturer of the laptop to download another touchpad driver
if acer www.acer.com if hp www.hp.com if toshiba www.toshiba.com etc etc go to support/downloads look for your make model and operating system
then scroll down for the touchpad driver
download it
install it
then restart
and hopefully this will correct it
Feb 18, 2011 | Computers & Internet
My mousepad's scroll feature is no longer working after I took my laptop to Best Buy and had them install a new harddrive under warranty
Right above the Touchpad is the On/Off button to Enable the Touchpad, or Disable the Touchpad.
If the Touchpad light is on, then the Touchpad is Enabled. (The On light is right above the Touchpad also)
Do you have the Touchpad enabled?
Dec 12, 2009 | HP Pavilion dv1000 Notebook
My laptop is an HP dv6000 and all of a sudden the scroll button on my touchpad doesn't work. The touchpad is still working, it's only the scroll button that doesn't work. What should I do??? Please help....
Go to the device manager and look up the mouse. When you open it, there should be a tab at the top that says device settings. Click on this tab, it is for the touchpad. Go through the settings for the touchpad and make sure that scrolling is enabled.
Nov 07, 2009 | HP Pavilion dv6000z Notebook
Scroll feature on touchpad no longer works
i did a system restore to take the laptop back to how it was before some automatic updates had taken place and now its working again.
ok, not the best solution i know, but at least its resolved the problem for now.
thank you.
kind regards
jackie
Oct 17, 2009 | Acer Computers & Internet
Scrolling button on touchpad
buy an opticalmouse suitable for notebook only im pretty sure that your problem is solved.
Nov 28, 2008 | Computers & Internet
Touchpad's scroll button not working
Download and install this driver:
http://www.acerpanam.com/synapse/data/7117/documents/Touchpad_Signed_Synaptics_v9_2_3_1_C.zip
Sep 10, 2008 | Computers & Internet
HP Compaq Presario CQ60Z Notebook Logo
534 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
