Question about HP OfficeJet 6210 All-In-One InkJet Printer
Hp 6210 not powering up i have replaced power cord
    Sergeant:
  • 259 Answers
Dear this problem is not a power cord but chane the power adeptor and open the printer beck side and check the mail conector in printer ............ok
Posted on Jul 14, 2009
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: problem in power supply
you changed the cord or the power supply?
Posted on Oct 26, 2007
dnewcombe1
  • 1564 Answers
SOURCE: Need replacement power cord for HP psc 1210 printer.
This printer utilizes a power cord identicle to one used on a PC.
Posted on Sep 30, 2009
Testimonial: "This is great! I've spent a week searching for an answer and getting nowhere. Here I get an answer within an hour. Unbelievable!"
  • 3 Answers
SOURCE: I have the HP Officejet 6210, it prints but will not scan
If you are flat bed scanning then try this....Try scanning through the top feeder instead. Mine has had this problem before and it has solved it.
Posted on Dec 23, 2009
We lost the powercord...can we get a replacement?
If you mean the power cord from the wall AC outlet to the power module, you can find those any place that sells computers. It's a standard 3-prong power cord used on almost everything now. If you mean the power module that connects to the printer, it's available direct from HP, but it's also available from many eBay sellers and other sources at a much lower price. Search eBay for "Q7310-60003", the part number, and you'll find a bunch to choose from.
May 16, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Hp 6210 all in one won't print. Neither the fax
Power off for one minute at least! Power on. self test should run. follow directions on LED screen of printer.
Nov 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a hp officejet 6210 all-in-one printer. When I copy from the glass vs. the feed, I see thin, vertical, black lines running down the page.
clean the glass or try following steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My HP 6210 prints blurry BUT not all the time?
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP office jet 6210 scanner failure error
have you tried to reset the printer?
(Take the power cord off hold # 3and then turn the printer on.)
That is an initial position problem
Parts are no longer available for this model from HP...
Jan 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Mar 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
