Question about Refrigerators
Frigidaire ice maker phsc239dsb0
I replaced my entire ice maker last month. It worked fine until this week and has suddenly stopped making ice. The arm is down, it's on, it's cold enough, nothing has changed with the water line, and the filter was recently replaced. Any thoughts on why it won't produce ice? There's minimal ice build up in the maker that hasn't released, but not much- not full cubes. Should I melt this off and see if that helps?
  • Anonymous Dec 27, 2007
    ice maker is not producing ice. It's been 4 days now. HELP!
2 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Frigidaire phsc239dsb0 ice maker
Yes it is best to replace the whole icemaker.  Heaters don't go bad very often but thermostats do.  You need to know what you are doing to test these parts.  I would recommend replacing the whole ice maker and I have worked on thousands of them.
Posted on Oct 14, 2007
Ice maker not working
Try filling with tap water and allow water to freeze. Once the water freezes and ice dumps into ice bin and water does not refill this will point to the dual water control valve. On the Model FRS6R5ESB0 that part is a Triple Water Control Click Here=> 241734301 Water Inlet Valve I will be here should you have questions but for now please try the tap water fill test and let me know how that turns out, Thanks, Sea Breeze
Mar 20, 2012 | Frigidaire FRS6R5ESB
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Oct 13, 2007 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
