Question about Electrolux Heating & Cooling
Hi, I have a KSR27g split system air conditioner. The unit turns on with the button on the front under the panel. The unit will not turn on with the remote (remote is brand new) have tried different batteries. any help.
    Sniper:
  • 81 Answers
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Posted on Jul 17, 2009
  • 30 Answers
Posted on Jul 15, 2009
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
I have an error code ch 61 on my LG system
Hi, Please open the front panel of the air con and look for the reset button on the electronic board, press it once. the system will initialize, then you will see all the LED lit randomly wait for a second then closed the front panel and test it. thanks
Apr 24, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Fan is set in auto position but keeps running
Hi Patsy go to circuit breaker panel and turn off breaker to blower unit.Count to 5 and turn back on.I hope it is labeled which breaker.
Apr 01, 2010 | Friedrich M18CF Split System Air...
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
May 08, 2009 | Sanyo 18KS52 Air Conditioner
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Heating & Cooling Logo
618 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
