Question about Tunturi R30 Rowing Machine
The rewind mechanism on my R30 Rowing machine does not work! The mechanism does not recoil. Can anyone advise? Thanks. Paul
Where can I get recoil spring for my rogerblack rowing M/C
The helpline number for this product is BENNY SPORTS 0153 563 7711
Mon - Fri 9.00am to 5.00pm,
Aug 18, 2015 | Exercise & Fitness
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
Help with kettler Isis rowing machine
The rower has been pulled off of my kettler isis magnetic rower. i have opened it up and cannot work out how to put reattach the line. can anyone help or send me a link to show me how to do this??
Aug 02, 2012 | Kettler Exercise & Fitness
I have problem with Carl Lewis RO84 magnetic rowing machine, cord goes slack
dEAR Sir:
Adjust the damper on the rowing machine. The damper controls the amount of drag you are experiencing as you pull. It is supposed to simulate the drag in the water. Most rowing machines have 10 levels. Between levels 3 and 5 will be your closest simulation to the water. Consider this for your exercise if you are training to be a rower.
ernesto cuadra
managua, nicaragua. c.a
Mar 10, 2012 | Exercise & Fitness
Has ceased to recoil
It sound like the return assembly cord has broken. If you mechanically incline then I suggest you pull apart your unit, but take pictures every step of the way until you uncover and inspect the return assembly. If you are not mechanically incline and since I don't know where you are located, go to the Tunturi website and locate your distributor they will be able to help you with parts availability, pricing and locate a servicer for you.
May 29, 2010 | Tunturi R30 R30 Series Rower
The cord sounds like its came loose and won't spin the engine
you need to remove the re-coil mechanism and if the cord isnt too bad retie it on the recoil and rewind the recoil spring and reassemble to the blower
Mar 19, 2010 | ECHO, Inc. PB-251C Handheld Blower
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
The chain has become completely loose and will not recoil, ?
You didn't say what model you have, but I believe they are all functionally similar to my Model B rower. There is a "skewer" assembly inside the seat rail with a shock cord and pulley's that keeps tension in the chain throughout its range of travel. To some extent it is adjustable by taking slack out of the shock cord. On mine, this can be done by grabbing the shock cord adjustment mechanism ("SCAM") with pliers and pulling it out of the rear of the machine and adjusting the slack. If it is very loose or you just want to be sure of what is going on, the entire skewer assembly pulls out from the front (flywheel side) of the seat rail after removing four screws that hold it in place. Go to the concept2 website for diagrams, instructions, and parts lists for your model.
Jan 18, 2009 | Concept2 2 Rowing Machine
Tunturi R30 Rowing Machine Logo
78 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
