Question about Nokia N72 Cellular Phone
Nokia N72 not responding
N72 switch off button not working at all and phone keeps going to blank lit screen every now and then help please. have done formating and update.
My nokia n72 phone's flash is not giving proper light when the flash is on.Rather it gives a faint light.pl.solve my problem
please format the phone , use this code to format the phone
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
then try to use the camera and check the flash,
if the problem check the flash hardware
Oct 25, 2010 | Nokia N72 Cellular Phone
I am unable to put the lock on my cell nokia n72. my cell code is 359400003259792 please send me master code.
first try to format the phone using the code below
your problem is again continuing go to a mechanic and ask him to flash the mobile ( re-install the software ) it costs around rs 100 to 150 - this helps to reset the code
please rate me if it helps u
Oct 22, 2010 | Nokia N72 Cellular Phone
Displaying white screen on switch no
Try switch off and wait for some minutes, switch it on back, if it is still blank screen you are getting, then, the problem with your phone is that the screen of your phone is damaged.
All you need to do is just to get a brand new screen on your phone and you see that it will display back.
Please, go with the phone while going to change the screen in other to get a the exact screen and a working screen.
Also note that, if the phone is slide, it is the flex on the phone you will just change, not the whole screen.
Take care
Jul 21, 2010 | Nokia N72 Cellular Phone
Hai iam using n72 it falldown and it switch off i
Oh, very bad. Think you try remove the battery and insert again, turn on the phone. If it's still show blank screen, maybe your phone was crashed. Bring it to Nokia care, maybe they can help you!
Mar 13, 2010 | Nokia N72 Cellular Phone
Font of n72
goto menu --> settings-->display--->font size --->set font size to normal or small.that will do... plz rate me !! if it helps ,if not feel free to comment
Feb 14, 2010 | Nokia N72 Cellular Phone
My Nokia N72 Gallery is not opening. When I press the gallery key the screen goes blank for some some time and then again display previous screen. Can anyone solve the problem?
Nov 05, 2009 | Nokia N72 Cellular Phone
How 2 work my N72 if screen is blank wen turned on?
u first uninstall the game then tak of the battery and keep out 4 som time. and then put it in.. tis mite help u.. if ther prob exists stil then u ll hav to contact the service center
Dec 13, 2008 | Nokia N72 Cellular Phone
Formsttong n72
There r two ways to format ur Cell Phone1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370# or dial *#7780# this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format, u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
  Call Button (green key) + * key + 3 at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
Doing HARD CORE FORMAT might help u in resetting the password.
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
Sep 08, 2008 | Nokia N72 Cellular Phone
N72 screen blank.
Just Update ur Phone Software.Remove ur memory card and update.It will do well
May 15, 2008 | Nokia N72 Cellular Phone
How to format n72 cellphone not memory card only cellphone
this is a simple one that so many people ask ,there is no risk to do just do as i say
if u want to format memory card first format it,then
to format phone,,,,,,,
first remove memory card,then switch off the phone for 2 min and then switch on by pressing n holding the keys ASTERIK(*),3,CALLKEY(GREEN KEY).THATS ALL PHONE COMES TO ORIGIN.
NOTE:THREE KEYS SHOULD BE PRESS N HOLD WHILE SITCHING ON.
AFTER GETTING SOLVED U JUST VOTE ME / MSG ME.OK GD BYE...
Feb 18, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
101 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
