Question about Compaq Presario M2000 Notebook
Trouble with power supply in lap top - Compaq Presario M2000 Notebook
    Master:
  • 568 Answers
Dear Contong
please have a check wit your charger, check it if it is working properly.
if it doenst make any change please take it to service center
Posted on Jul 14, 2009
My lap top saids operating system not found
Check your power supply and DC socket connections.
Oct 05, 2016 | Computers & Internet
The lap top power supply goes off automatically while working sessions
It seems the game giving lots of pressure to your problem and there might be some dirt which is blocking your processor to cool down, So first I'll suggest you to Clean the Processor FAN dust properly and apply heat sink paste on top of the fan.
Aug 04, 2012 | Acer Computers & Internet
I have a Compaq M700 lap top. power failure , Won't boot up ?
You need to find out if the power supply was damaged, it would have been the first to take a hit, remove the main battery to see if it will boot because a bad one will load the system down in some cases. One trick that might work, unplug power supply from laptop and remove main battery, now press and hold power for 2 minutes to drain off residual voltage and reset the processor, finally install everything back and power up.
May 03, 2012 | Compaq ARMADA M700 PIII500 MHZ LAPTOP...
The lap top wont turn on. I tried to remove the battery then plug in the power supply and still it wont turn on. The blue light on the power supply turns off as soon as you plug it in to the lap top.
PLACE YOUR SYSTEM UPSIDE DOWN AND REMOVE THE BATTERY AS ITS TEMPERATURE IS IN WORSE STATE .TRY TO COOL IT DOWN .IN FUTURE PLACE YOUR SYSTEM ON SOME MATERIAL SO THAT THE AIR SUPPLY REMAINS CONSTANT AND TEMPERATURE OF SYSTEM DONT REACH ITS CRITICAL RANGE.
Jul 22, 2011 | Dell XPS M1330 Notebook
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
How do I charge my battery on my t30 lap top battery
You normally need a compatible Power Supply plugged into the Laptop from the mains. Without this the battery will go flat. If you do not have one a good place to look is Ebay, or the like simply put in the model name of your laptop and the words Power Supply.
EG: IBM ThinkPad T30 Power Supply.
Feb 03, 2010 | IBM 11P8273 for Thinkpad 14.1" Flat Panel...
Playstation 3 power up.
It appears to be a power supply issue. Try installing a new power supply. If this helps, please rate me.
Apr 15, 2009 | Sony Playstation 3 (PS3) Console
Problem with cd/dvd drive
you have to open the lap top and check the power supply cable, if it is loose.if your are not familiar with open the cashing of the lap top then ask some professional to help you.
Jan 13, 2009 | Acer Extensa 4620 Notebook
MY ACER ASPIRE 1640 LAP TOP WILL NOT STAR UP. WHEN TURNING ON THE POWER BUTTON FLASHES ON AND OFF. WHEN PLUGGED INTO THJE MAINS THE CHARGING LIGHT SHOWS YELLOW BUT THE COMPUTER WILL NOT TURN ON
check the power supply to the mains where the lap top is plugged and comfirm if there is power supply and for any possible drop in power output which may affect the charging
Aug 04, 2008 | Acer Computers & Internet
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
