Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker dispenses too much water into tray and causes overflow problem and too large of a frozen mass to dispense. Kenmore side by side model 106.955761.
  • rogerp Nov 20, 2007
    the dispenser releases too much water at a time, making the cubes one big frozen clump that cant be dispensed.
  • pmartin Jan 11, 2008
    My ice maker makes ice but when tray begins to refill, it overflows which causes the newly made ice to freeze together in one clump and is unable to be dispensed.
How do you increase the ice cycle?
Posted on Mar 04, 2008
  • 55 Answers
Check if you can increase the ice cycle
Posted on Nov 18, 2007
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
After replacing ice maker assembly, ice is not getting made?
Ice maker is leaking water and causing the ice to freeze?
Ice maker is noisy and not making ice?
Refrigerator ice maker stopped making ice?
Ice maker leaks water into ice bin causing a glob of ice?
Amana Refrigerator leaking water from ice maker?
Ice maker leaking?
Ice maker is dumping the ice cubes out before frozen solid.
Water overflowing ice maker?
Ice cube is getting stuck up hard in ice maker
Icemaker quit working?
Quit making ice
Water leaking into ice tray, frozen glob of ice
Not making ice, and water leaking in freezer?
The ice maker stopped making ice?
Ice maker not making ice?
Ice maker quit working?
Ice maker dispensing black pieces of plastic in the ice?
Replaced Ice maker but its still not making ice?
Ice maker leaked creating an ice block?
Ice tray leaked?
Ice maker stopped functioning?
Ice maker stop working?
Ice maker failed
Old ice maker stopped working?
Old ice maker started leaking?
Ice maker not working?
Ice maker overfills and cause water to flow into ice dispenser and freezes?
Ice maker didn't make ice?
Ice maker was leaking?
Ice maker was leaking after it filled up with water?
These will help.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Water dispenser works, but ice maker not working.
i have the same problem right now.. water supply is goodand water dispenses from dispenser. tray that makes cubes not getting any water. looking for help also.
Dec 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker problem
Good Morning,the solinoid valves are crossed in the back of the refrigerator. shut the water off and switch the tubing around that comes off of the valves
Dec 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Too much water getting to ice maker
The little cup that sits in front of the hose that dispenses the water, has frozen water in it . Check that first and if it's OK, then there is a small screw that you can adjust, look at your manual.
Nov 03, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
199 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
