Question about Alpine CDA-7995 CD Player
I have an older model high end alpine cd deck. It has rca sub outs front and reat rca outs as well as high level straight wire outs. It also has the standard power antenna wire and remote on wire. It also has large gauge RCA type wire with what is called a dc to dc converter. Does anyone know what this is? What does it do? And Why does a dc powered vehicle deck need a dc to dc converter? The unit was installed and performed nicely in my 65 GMC pick up w/ some MTX 4.25's. I have yet to try the other function. The entire time it was in the truck, the dc converter was not attached to anything and the manual says nothing about it. I'm going to do a complete more advance install w/ the unit subs, amps and cross overs. Will I need to attach this converter to something somehow? There are no obvious plug ins or places to attach wire to the converter and again.. the manual says NOTHING about it. Any information would be greatly appreciated.
4 Suggested Answers
  • 10 Answers
SOURCE: no sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Posted on Sep 03, 2007
  • 11 Answers
SOURCE: How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Posted on Nov 03, 2007
hack124x768
  • 33 Answers
SOURCE: connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Posted on Mar 28, 2009
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
I have an Alpine MRD-M605 amp that recently has started having issues. My subs only produce sound when my deck is turned up full blast. The setup had been working for over a year with no problems. The subs...
If your deck is aftermarket; Does it have a dedicated Subwoofer output? if so, check the control in the deck (sub gain). If you are using a factory radio, and a high to low level adapter (speaker wires to RCA), it may be bad (not too uncommon) or check your fader front/rear any difference? Otherwise, you have one of two problems. A bad preamp in the deck or a bad pre amp in the amp. Both are fairly uncommon. More than likely it's a setting. Hope this helps
Jun 23, 2009 | Alpine MRD-M605 Car Audio Amplifier
Alpine eq 3331 install
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
Alpine type-r 2ohm dual voice coil help
try reconnecting your rca's from the deck to the amp when finished wire one speaker positive to positive on left channel and negative to negative on right channel then connect the 1st subwoofer. if all power and sound is fine and working turn off power to amp and connect negative terminal of 1st sub to positive on 2nd sub and positive from first sub to negative on second crossing the wires runs the speakers in series another way to try is parralel the speakers wiring by connecting positive left channel output of amp to positive on 1st sub same with the negative then splice positive to positive on second sub and same with negative.
Feb 09, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
Swapped out cd players now getting high pass through subs
this is very easy...just unplug the rca cables out of the back of the deck, and plug them into the "subwoofer" output. On some alpine decks this is on a "pigtail" wire that extends from the deck. Once this is connected to the right output, you can control the subwoofer level from the volume knob by pressing it inwards.
Also.... your amplifier should have a low pass filter, it should be on a switch marked "LPF". Make sure this is switched on.
Feb 25, 2008 | Car Audio & Video
No sound to the in car speakers from my alpine cda-9827 cd player
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine CDA-7995 CD Player Logo
170 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
