I have an ASUS A6000 laptop which has worked fine for over 3 years. I recently left it powered off for over 1 week and now it won't boot from either hard disk or the original ''Recovery'' CD. Powers on OK but get nessage to ''Reboot and select proper boot device or Insert Boot Media in selected boot device and press a key''. Any guidance would be much appreciated.
    Problem Solver:
  • 10 Answers
Hi, you'll have to go to bios/Cmos settings& set the bootable media as your CD/DVD rom drive name & you can try to recover it.
Regards
Kunal
Posted on Jul 14, 2009
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
I have an Asus Striker Extreme III motherboard running a q6600 with 4gb of patriot 1066 ram and an asus 8800 gtx video card. My computer has run fine for the last 3 years and had been working fine. Then a...
This sounds like the power supply - before buying a new motherboard can you get voltages from the pin connectors that power the board? You can use a simple multi-meter - set to 12V and register the current.
May 01, 2017 | ASUS Striker Extreme Motherboard
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
My ASUS P5QL Pro motherboard will not boot up correctly quite often. I have swapped RAM, power supple, video cards and i made no difference. the last time i pulled the bios battery and the bios chip,...
i had just solved this problem yesterday, there this symptom below please checked.
1.won't boot after power on button 2.LED on motherboard is light
3.unable to BIOS setting screen 4.CPU fan doesn't work
How to solve
How to solve
1.Please find this IC on motherboard EPU asp0800 near the CPU Socket
2.Press the IC with finger,at the same time press the power buttom
(If CPU fan is running on short time please do step 3 )
3.Power on your soldering iron and contact each side of this IC about 3 seconds( soldering iron to contact IC lead left to right or right to left)
4.Review each side of IC and check any short between IC lead5.After step 4 done, power on pc again, if PC booting congratulation
6.Final check: put finger on ic top side surface (don't touch the IC lead)feel the temperature if too hot that's mean short between IC
lead,please rechecked step 4
Sep 24, 2010 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
ASUS a6000 km boot problems
check your ram, hard disk and operating system
Aug 22, 2009 | Computers & Internet
Asus F3S Laptop Graphics Card Died
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning.
Try connecting and external monitor to your laptop and the boot up your laptop.
Then :-
1. Download the latest graphics driver from ASUS WEB site.
2. uninstall the graphics driver.
3. Reboot the laptop and install the new graphics driver.
4. Shut down and remove the external monitor and reboot.
5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
Nov 13, 2008 | ASUS R1E-B1 Tablet PC
Asus A6000 power shutdown
The CPU heatsink has it's thermal paste dried. Fixed one A6000 with this fault. Works perfect now.
Sep 25, 2007 | Computers & Internet
Computers & Internet Logo
587 people viewed this question
David Payne
David Payne
