Ge window a/c blows cool air for a few seconds then stops cooling
I have a Ge 8000 Btu window air conditioner thats three years old. I only used it for a couple weeks when it was new and put it in storage. Recently I put it in the window and it blows cool air for a minute then stops blowing cool air. Its more like a fan now. I took it apart and looked on the inside and everything looked fairly clean. Any help will be greatly appreciated. It was 104 degrees today lol.
    Problem Solver:
  • 9 Answers
Is it LEVEL. Must be somewhat level to work effeciently. Probably had a seal in the pump dry up, worst thing for an ac is to let it set too long. Also, if you tipped it on end while moving you MUST let it set for a few hours (24 is best) before using or you risk scorching the walls of the compressor cylinder because the oil sometimes doesn't get pumped until settled back to bottom. If you can touch the copper tubing going into and out of the compressor, one should be much hotter than the other, if not either low on charge of coolant or compressor shot----if you DO have a difference in temp you probably have a bad thermostat/cycling switch.
Posted on Jul 14, 2009
  • 716 Answers
Its Most Likely Lost Its Freon Or The Compressor Seals Are No Good When The Unit Is On See If You Hear A Whirling Sound Alot Like Your Fridge. Put Your Hand On The Compressor To See If Its Vibrating ( Looks Like A Metal Ball) If It Is Have A Ac Repair Place Check The Freon To See If It Has Run Out Or Is Low. If It Doesn't Feel Like Its Running Have Them Check The Compressor For You. Cooling System Components Should Not Be Serviced By Anyone Who Has Not Been Properly Trained To Deal With Freon.
Sincerely,
Michael Scott
Testimonial: "That seemed to be the problem. Thanks!"
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Aug 17, 2016 | Frigidaire FAS256R2A 25,000 BTU Window Air...
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
I bought a ge 8000 btu portable ac unit but i don't know how to get it into cool mode it will only run when fan is on. should the same picture on the remote be on the screen of the ac unit. how long should...
mcdevito75 here, First Place the FAN on low or it may not say fan rather low cool, for 3 minutes, then the other control to 60--65 degress or 1/2 way thru the Blue indication on that control, compressor should come on. If it"s an old unit in need of service 2years old or older check out your local A/C repair shop they come to the house, also you can clean or replace the filter just under the cover where the controls are. FAN or LOW COOL FIRST FOR 3 Minutes, then Teperature to 60--65 degrees.
Jun 25, 2010 | GE AJCQ08ACB Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Whirlpool air conditioner - 8000 BTU - window unit
Your parents must be proud of you! You must have a big red "S" upon your chest!
Aug 22, 2008 | Whirlpool Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
