Question about Samsung Office Equipment & Supplies
Fax machine is saying paper jam but does not appear to have paper jam
    Problem Solver:
  • 5 Answers
I have been having the same problem with my fax.
If you switch off the fax machine for 30min then switch it back on again the fax will resets its self and this should clear the error.
Martin
Posted on Jul 14, 2009
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
May 27, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Paper jam
My KX-FT73CX Fax always Paper jam when turn the machine
Sep 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Paper jam
Open the front cover and look at the white roller. Is there anything jamming that? Like, say, a broken clip that's meant to hold the front cover in place as I just found happened to our fax machine.
Apr 05, 2007 | Samsung SF-335T Plain Paper Inkjet Fax
Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
Jan 30, 2007 | HP 1040 Plain Paper Inkjet Fax
138 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
