Rinnai gas heater - to start requires that I turn a knob a half turn and hold for 15 seconds and then release. Currently it starts ok but I release the knob the heater stops. Is this something I can fix myself?
  • blender719 May 11, 2010
    Specific model??? I am a Rinnai New Zealand service agent, need more info.
    Scholar:
  • 83 Answers
This sounds like you have a faulty 'thermocouple' (this is a safety device which the pilot heats up).
I wouldn't recommend you do it yourself, as you may invalidate your house insurance should something happen.
Ideally you should get a gas engineer in to change it, i know it's more expensive but at least you get piece of mind and a guarantee.
The part will cost no more than £25
I hope this helps
Steve :)
Posted on Jul 16, 2009
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
Nov 26, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a Rinnai R82VF LPG room heater. When you press the gas button and then turn the temperature control knob to IGN, it lights. When you release the temperature control knob, it springs back to OFF and...
Part of the problem may be, that when you turn the control knob to ignition, you're not holding it in long enough for Thermocouple or Thermopile to thoroughly heat up after the pilot lights. You should hold the bottom down for 30 seconds to a minute, to allow it to heat up. Then, when you slowly release it. If the pilot remains lit, turn the knob to the desire position.
If the above doesn't solve the problem, the Thermocouple or Thermopile (aka Pilot Generator) will need to be replaced.
Hope this helped you. Cheers
Jul 08, 2011 | Heating & Cooling
How do you light the rinnai glo-ray heater
Without pushing in the knob, turn knob to "IGN" position, THEN press and hold in knob while in that position, repeatedly press "Ignitor" button. (If it's the first time you've lit it, it may take up to 5 minutes of doing this to get the gas line supply full enough to light the pilot.) After the pilot is lit, continue to hold in "IGN" button for 10 seconds, then release, then you should be good to go.
Nov 22, 2010 | Rinnai Heating & Cooling
The pilot is off and I don't have the manual. How do I start the pilot to turn on the logs
You will need to find the gas valve. Open up the lower section of the fireplace and look foe a small cube of aluminum with a knob on it that says On-Off-Pilot. Turn the knob to the Off position by lining up the word with a small dot or line indicator on the body of the gas valve. Then turn the knob to the Pilot setting. You will know when you are in the correct setting because you will be able to depress the knob into the gas valve body. Hold the knob depressed and click the larger red button. It will snap so don't be startled. Continue to hold the knob in while looking between the logs for a blue flame. If you don't see one, keep snapping the red button. Once you see the flame, continue to hold the knob depressed for 30 seconds or so. Release the knob and make sure the flame stays on. If it does not, repeat nthis procedure and hold down the knob for 45 seconds. If the flame continues to go out, you need a new thermocouple. Once the flame stays lit, rotate the knob to the On setting. The main burner should start within 15 seconds.
Nov 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Pilot light will stay lit as long as i hold down the knob, but when knob released, light goes out....... i have a wall mount model# GWRN30t
Normally when you release the knob it work the same as a two way switch ,which mean gas will stop flowing through the small pilot channel and will flow to large channel where it will continue to burn.
In your case, you have to strip down the regulator switch and look where the gas passage is glogged.
Oct 05, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
