Question about Thor Motor Coach 2005 Four Winds Intl. Hurricane 30q
Where is the converter located - Thor Motor Coach 2005 Four Winds Intl. Hurricane 30q
  • 37 Answers
In the exhaust pipe under the vehicle
Posted on Sep 28, 2017
Location of code p1137 on 01 alero
catalytic converter .
In order to control emissions, a catalytic converter converts any harmful exhaust emissions into harmless water vapor and carbon dioxide.
The powertrain control module (PCM) has the capability to monitor this process by using a rear-heated oxygen sensor (HO2S 2). The HO2S 2 , located in the exhaust stream past the catalytic converter, produces an output signal which indicates the storage capacity of the catalyst. This in turn indicates the catalysts ability to convert the exhaust emissions effectively. If the catalyst is functioning properly, the HO2S 2 signal will be far less active than the signal produced by the front oxygen sensor (O2S 1).
Feb 12, 2017 | 2001 Oldsmobile Alero
How many o2 sensors on a 99 Cadillac catera
Four .
Heated Oxygen Sensor (HO2S Bank 1 Position 1)
Located in RH front pipe of the exhaust catalytic converter
Engine Controls Connector End Views in Engine Controls
Heated Oxygen Sensor (HO2S Bank 1 Position 2)
Located in RH rear pipe of the exhaust catalytic converter
Heated Oxygen Sensor (HO2S Bank 2 Position 1)
Located in LH front pipe of the exhaust catalytic converter
Heated Oxygen Sensor (HO2S Bank 2 Position 2)
Located in LH rear pipe of the exhaust catalytic converter
Sep 21, 2015 | Cadillac Cars & Trucks
Anyone has a diagram or pictures from 1995 Mercury Villager showing the location of the two Oxygen sensors, and which one is Front and which one is Rear? Thanks in advance
oxygen sensor are located before the cat converter and after the cat converter. The unit before tha cat converter is normally in the exhaust manifold or in the exhaust before the cat _ it is a heated oxygen sensor (HO2S) the one after the cat converter is located either in the end of the cat or close to in in the exhaust pipe. Its defines as an oxygen sensor (O2S). If you have 2 cat converters (V engines) there will be two of each
Jan 22, 2015 | Mercury Cars & Trucks
E-Check Light P0125 and pending p1153/p1155. Replaced ECT and codes reappear. Where is this Bank2 Sensor1 located on my 1998 toyota camry v-6 auto with air. P1155Code book described as AF sensor.
Air/Fuel Sensors are mounted upstream of the catalytic converter. They are located on the exhaust manifold side of the catalytic converter (pre-converter - Sensors 1). Oxygen Sensors are mounted downstream of the catalytic converter (post-converter - Sensors 2). The catalytic converter has two chambers (left and right). Bank1 is left, drivers side. Bank2 is right, passengers side. The Bank2 Sensor1 sensor (Air/Fuel Sensor) is the one located on the 'right and ahead' of the converter. The PowerTrain Control Module (PCM) is reporting that the heater or circuit ( wiring / plug-in) of the sensor is malfunctioning.
Jan 31, 2011 | Toyota Camry Cars & Trucks
Were is located the oxigen sensor in expedition 1999
They are located in the exhaust pipes under the car. There will be two before the catalytic converter and one after the catalytic converter. the two before the cat are usually located closer to the exhaust manifold. The one after the catalytic converter will be right behind it.
Which one do you need to replace?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 05, 2010 | Ford Expedition Cars & Trucks
I need to know how many 02 sensors are on a 1997 dodge intrepid.
  • Up-stream sensor (located before catalytic converter)
  • Left up-stream sensor (located before catalytic converter)
  • Left down-stream sensor (located after catalytic converter)
  • Right up-stream sensor (located before catalytic converter)
  • Right down-stream sensor (located after catalytic converter)
4 sensors total.
Jul 29, 2010 | 1997 Dodge Intrepid
Where is the oxygen sensor on 1997 ford taurus wagon 3.0
Single or double overhead cam type engine? In any case, these are the locations listed below.
May 04, 2010 | 1997 Ford Taurus
Where is the Torque Converter clutch solenoid located on a 2005 Chevy Cavalier Auto Transmission?
Actually, the Torque Converter Clutch Solenoid is located within the transmission housing that is easily accessible through the transmission oil pan. The TCC solenoid may vary in location dependent upon manufacture but generally it is located as aforementioned. It can cause your vehicle to stall if stuck open or close because it controls loads to the engine via your torque converter which is located between the vehicle's engine and transmission. Also, make certain that you attempt to change the transmission fluid and filter before changing the TCC solenoid because that may be your underlying issue. If not, simply reuse your fresh oil and change the TCC soleniod.
Apr 27, 2010 | 2005 Chevrolet Cavalier
02 censor
Your car should have two O2 sensors. One will be located after your catalytic converter. The other one should be located before your catalytic converter somewhere between your headers and your cat. Rarely, on some vehicles, there's a 3rd O2 sensor which is located also somewhere between the catalytic converter and the headers.
Oct 29, 2009 | 2004 Chevrolet Impala
Where is the bank 2 sensor 1 located.
Oxygen sensors are always numbered like this:
Bank 1 sensor 1
Bank 2 sensor 1
Bank 1 sensor 2
Bank 2 sensor 2
some manufacturers use a kind of shorthand that reads different, but means the same thing:
Sensor 1/1 or O2s 1/1
Sensor 2/1 or O2s 2/1
Sensor 1/2 or O2s 1/2
Sensor 2/2 or O2s 2/2
Bank 1 is always the side of the engine where cylinder number 1 is located and, of coarse, Bank 2 is the opposite side.
On a 4 cylinder engine, there is only 1 bank and it is always referred to as Bank 1.
Sensor 1 is always the upstream sensor (The one located BEFORE the catalytic converter)
Sensor 2 is always the downstream sensor (the one that is located AFTER the catalytic converter.
Most GM engines have #1 cylinder located on the left bank, (or Driver's Side) of the engine,
So, the answer to your question would be that you are looking for the sensor located before the catalytic converter on the right (or Passenger Side) of the truck.
Oct 17, 2009 | 1996 Chevrolet K1500
Thor Motor Coach 2005 Four Winds Intl. Hurricane 30q Logo
828 people viewed this question
Top Thor Motor Coach Event Planning & Celebration Experts
JonSnell Electronic
JonSnell Electronic
Andrew Taylor
Andrew Taylor
Geoff Tuke
Geoff Tuke
Level 1 Expert
Are you a Thor Motor Coach Event Planning and Celebration Expert? Answer questions, earn points and help others
