Question about Dryers
Dryer wont tumble the belt has come off and also the spring system, ho can this be fixed?
  • 315 Answers
Follow the bellow steps in order to replace the belt:
  1. Safety first! Unplug the machine from the wall-socket and make sure the machine has been idle long enough so that the heater elements, etc. have cooled.
  2. dryer wont tumble the belt has come off and also - 180px-p3090017.jpg magnify-clip.pngTop cover removalRemove the top cover of the machine by undoing the 2 bolts at the back of the top panel.
  3. 180px-p309dryer wont tumble the belt has come off and also - magnify-clip.png magnify-clip.pngTop cover removedYou should now be able to see if the belt is broken or not. It should be wrapped around the back of the drum. In this pidryer wont tumble the belt has come off and also - 180px-p3090047.jpg it has snapped and is loose on the drum.
  4. 180px-p3090047.jpg magnify-clip.pngRemove plastidryer wont tumble the belt has come off and also - 180px-p3090019.jpgplastic cover at the bottom rear of the machine and take off the black belt going from the reddryer wont tumble the belt has come off and also - magnify-clip.pnghite pulley (this turns the fan).
  5. 180px-p3090019.jpgAir-flow coverAt the back of the machine, undo the 5 or 6 bolts securing the air-flow cover...
  6. 180px-p3090020.jpg magnify-clip.pngAir-flow cover removed...revealing dryer wont tumble the belt has come off and also - 180px-p3090034.jpge-ring and washers.
  7. Remove these and keep them in a safe place for ndryer wont tumble the belt has come off and also - magnify-clip.png"http://www.wikihow.com/Image:P3090023.JPG">180px-p3090023.jpg dryer wont tumble the belt has come off and also - magnify-clip.png> & washers
  8. 180px-p3090034.jpg magnify-dryer wont tumble the belt has come off and also - 180px-p3090025.jpg_midrum and back panelThe drum is no longer holding in the back panel of the machine. dryer wont tumble the belt has come off and also - magnify-clip.pngi"> 180px-p3090037.jpg magnify-clip.pngBack PanelUsing a 7mm socket wrench, remove the screws holding in the back panel of the machine. Take care to support the panel (and the drum) as the screws are removed. A second pair of hands is useful here!
  9. 180px-p3090025.jpg magnify-clip.pngBack panel removalTaking care to support the drum, move the back panel away from the machine slightly. Do not move more than a few inches yet!
Posted on Jul 14, 2009
  • mithun dey
    mithun dey Jul 14, 2009
    Rest of the steps:
    1. Before removing the back panel any more, carefully undo the electrical connector for the heating element.
    2. Broken beltRemove the broken belt if not already done.
    3. Positioning the beltMove the back panel away from the drum and put the new belt over the top of the drum (towards the rear) and feed it through between the drum and the back panel and finally around the motor-shaft.
    4. Motor/Spring assemblyThe motor can pivot and has a spring securing it to the body of the machine.
    5. The trick to fitting the belt is to hold the belt with your left hand as shown and with your other hand, push the pulley-wheel anti-clockwise until you can get the belt to loop over it.
    6. The belt is looped around the pulley-wheelOnce this is in place, the hard work is over. Rotate the drum slowly by hand to make sure the belt is able to travel unhindered. Now is your chance to hoover out the back of the machine! Reconect the heating element connector.
    7. Re-fit the back cover, taking care to line up the drum with the hole.
    8. Screw on the back panel. Replace the washers/e-ring securing the drum.
      • Make sure you put back on everything you removed (such as the belt for the fan).
    9. Re-fit the top cover.
    10. You're good to go!
    Problem Solver:
  • 9 Answers
How old is the belt? Probably stretched so far that the spring couldn't supply enough tension to keep it on the pulleys. Need a new belt.
I am trying to change the belt on my electra tumble dryer but cant get it onto the spindle as there is a spring loaded pulley wheel also?!!!1
put the belt onto the tension pulley first then use the large diameter drum to assist you in in LEVERING the belt on with tensioner spring in place . Failing that remove and replace spring with vice grips (put spring back on as it came off ).
Aug 13, 2011 | Dryers
Kenmore 70 series dryer. Heats up but quit tumbling.
belt is off or broken here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 11, 2011 | Dryers
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
HOW DO YOU FIX A BELT ON MY ZANSSI DRYER ZDC46130S
remove back cover off dryer, put belt around drum and drive motor, pull spring loaded pulley back, as it will be resting on drum, feed belt around pulley. and reassemble back cover.
Jan 25, 2009 | Dryers
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Dryer not tumbling
Broken drive belt, or drive belt disengaged. Or stretched. Or lost tension spring. Humming is motor running, not driving drum.
Jan 21, 2008 | LG DLE5977 Electric Dryer
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Dryers Logo
386 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
