Question about Yahoo Messenger
I got problem when install libssl0.9.6
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package libssl0.9.6
    President:
  • 627 Answers
Better download pigdin from here http://pidgin.im/
is verty godd for linux based computers
Posted on Jul 14, 2009
Examples of common nouns
The noun 'language' is a common noun.
Other examples are '******', 'car', 'tent', 'rifle', 'gun', 'building' and 'edifice'.
for definitions and further examples see
http://www.chompchomp.com/terms/commonnoun.htm
(I thought that website explained things very well. one of many websites with such information)
8.June.2014
Jun 08, 2014 | Toys
Installation of sqldeveloper on ubuntu 12.4
First, make sure you have JDK 7 installed. Then,
  1. Install alien with the command sudo apt-get install alien. This is used to convert RPM packages
  2. Download the Oracle SQL Developer package if you have not done so already.
  3. Run alien on the RPM package: alien -d package.rpm.
  4. Install the package with the command sudo dpkg -i package.deb. If there is a message saying there is a dependency problem while installing it, you can fix it by running sudo apt-get -f install.
Feb 25, 2014 | Canonical Ltd. Ubuntu
Adrees Cheema
G6600 unlock done with infinty..........................
COM6 [VCP0] selected
module v3.62
Action: "sp-unlock"
unlock method: smart fast
Model: Huawei-G6600
Checking data, wait...
Phone should be Switched OFF !
Press and HOLD Power button now !
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: E5.2FY01V01.09
Version: BYD35_09A_PMWY_HW
82 byte(s) read
imei: 35751003xxxxxx
connection Ok
189 byte(s) read
reading data...
building new data...
writing data...
177 byte(s) read
reading data...
reading data #2...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 1 min 58 sec
Remove/Install battery now !
Feb 07, 2014 | Huawei Unlocked G6600 Qwerty Smart Cell...
I have been trying since Monday to have a question answered. I was chatting with one of your people on-line, and the System cut us off while he was looking up the answer. I couldn't reconnect to him....
Once you have configured all elements of an application's installation in your installer project (by specifying folder and file locations, file associations, registry actions, and so on), you must build the project into an installer package (.msi) file. Then, you can distribute the .msi file to users who want to install your application. If you change your installer project after building it, you must rebuild the installer project to test your changes.
To build an installer project into a package file
Make sure the Build type project property (on the Build Tab of the Project Properties dialog box) is set to either: Installer or Installer with Microsoft® Windows® Installer Loader.
2. In the Project Explorer window, select the installer project.
3. On the Build menu, click the option to Build your project. Note The Build menu may include options for building either your project or the entire solution.
1. In Windows Explorer, navigate to the .msi file you built with this project.
2. Right-click the .msi file name.
Note Depending on your system settings, the .msi file extension may not be displayed. You can still right-click the file name.
3. Select uninstall from the context menu.
4. In Visual Studio Installer, select the installer project from the Project Explorer.
5. On the Build menu, click the option to Build your project.
Visual Studio Installer builds your project and displays the message "Solution update succeeded" in the lower left corner of the development window when the build is complete.
Jun 10, 2011 | Computers & Internet
I want to set up a blog like www.100checks.com but dont know how?
Contact the company that is "hosting" your web-site.
They will recommend a package of "blogging" software that they offer to their clients.
They will install/enable the software onto your site.
Feb 12, 2011 | Computers & Internet
How to install package manager in ubuntu?
A package manager is a program that installs and uninstalls software, and keeps track of all the components each piece of software needs.
Dpkg is the Ubuntu package manager dpkg is a medium-level tool to install, build, remove and manage Ubuntu packages. The primary and more user-friendly front-end for dpkg is dselect.dpkg itself is controlled entirely via command line parameters,which consist of exactly one action and zero or more options. The action-parameter tells dpkg what to do and options control the behavior of the action in some way.
Now we will see all the available commands for dpkg with examples
1) Install a package
Syntax
dpkg -i <.deb file name>
Example
dpkg -i avg71flm_r28-1_i386.deb
2) Install all packages recursively from a directory
Syntax
dpkg -R
Example
dpkg -R /usr/local/src
3) Unpack the package, but don’t configure it.
Syntax
dpkg --unpack package_file
If you use -R option is specified, package_file must refer to a directory instead.
Example
dpkg --unpack avg71flm_r28-1_i386.deb
4) Reconfigure an unpacked package
Syntax
dpkg --configure package
If -a is given instead of package, all unpacked but uncon-figured packages are configured.
Example
dpkg --configure avg71flm_r28-1_i386.deb
5) Remove an installed package except configuration files
Syntax
dpkg -r
Example
dpkg -r avg71flm_r28-1_i386.deb
6) Remove an installed package including configuration files
Syntax
dpkg -P
If you use -a is given instead of a package name, then all packages unpacked, but marked to be removed or purged in file /var/lib/dpkg/status, are removed or purged, respectively.
Example
dpkg -P avg71flm
7) Replace available packages info
Syntax
dpkg --update-avail <Packages-file>
With this option old information is replaced with the information in the Packages-file.
icon_cool.gif Merge with info from file
Syntax
dpkg --merge-avail <Packages-file>
With this option old informa-tion is combined with information from Packages-file.
The Packages-file distributed with Debian is simply named Packages.dpkg keeps its record of available packages in /var/lib/dpkg/available.
9) Update dpkg and dselect’s idea of which packages are available with information from the package pack-age_file.
Syntax
dpkg -A package_file
10) Forget about uninstalled unavailable packages.
Syntax
dpkg --forget-old-unavail
11) Erase the existing information about what packages are available.
Syntax
dpkg --clear-avail
12) Searches for packages that have been installed only partially on your system.
Syntax
dpkg -C
13) Compare Package versions version numbers
Syntax
dpkg --compare-versions ver1 op ver2
14) Display a brief help message.
Syntax
dpkg --help
15) Display dpkg licence.
Syntax
dpkg --licence (or) dpkg --license
16) Display dpkg version information.
Syntax
dpkg --version
17) Build a deb package.
Syntax
dpkg -b directory [filename]
18) List contents of a deb package.
Syntax
dpkg -c filename
19) Show information about a package.
Syntax
dpkg -I filename [control-file]
20) List packages matching given pattern.
Syntax
dpkg -l package-name-pattern
Example
dpkg -l vim
21) List all installed packages, along with package version and short description
Syntax
dpkg -l
22) Report status of specified package.
Syntax
dpkg -s package-name
Example
dpkg -s ssh
23) List files installed to your system from package.
Syntax
dpkg -L package-Name
Example
dpkg -L nagios2
24) Search for a filename from installed packages.
Syntax
dpkg -S filename-search-pattern
Example
dpkg -S /sbin/ifconfig
25) Display details about package
Syntax
dpkg -p package-name
Example
dpkg -p nagios2
Please check if this is any help for you.
Regards.
May 26, 2010 | Computers & Internet
When installing a metal door in a brickwall, does a lintel have to be installed? I am directed to just use industry standard. Is there an industry building standard that states this? If so, would you...
The state you live in you should be able to contact building codes for you state to get an email address to ask this question.
I am sure you will have to put a lintel in when installing a door in masonary.
Apr 15, 2010 | Plumbing
How to calculate the length of cables and conduit pipes required in electrical wiring diagram of domestic,industrial installation
While determining the cable size makes sure that the wiring system should be in an open wiring system, the temperature would be low, but in conduit wiring, temperature increases due to the absence of air.
The key thing to find cable size is loaded, it depends upon the load how many loads exactly have.
Diversity factor in electrical wiring installation while selecting the proper size of cable for electrical wiring installation.
Apr 25, 2009 | Electrical Supplies
Discount offered
Depends on the state you buy in. I got my car (2008 CL550) from NJ, and got it at invoice price. The car is stocked with the following packages (black and black interiors): - AMG Package - Premium II - Distronic Plus - Heated stearing - Ipod integration The MSRP for this package was $120,080; I got the car for $112,000. Had to pay NJ taxes on top of that price though :-(
May 14, 2008 | 2007 Mercedes-Benz CL550 Coupe
Firewall is not configered is linux centos
try and go for it..all d best...
Use yum command as follows:
# yum install squid
Output:
Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package squid.i386 7:2.6.STABLE6-4.el5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: squid i386 7:2.6.STABLE6-4.el5 updates 1.2 M Transaction Summary ============================================================================= Install 1 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 1.2 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: squid ######################### [1/1] Installed: squid.i386 7:2.6.STABLE6-4.el5 Complete! Squid Basic Configuration Squid configuration file located at /etc/squid/squid.conf. Open file using a text editor:
# vi /etc/squid/squid.conf
At least you need to define ACL (access control list) to work with squid. The defaults port is TCP 3128. Following example ACL allowing access from your local networks 192.168.1.0/24 and 192.168.2.0/24. Make sure you adapt to list your internal IP networks from where browsing should be allowed:
acl our_networks src 192.168.1.0/24 192.168.2.0/24
http_access allow our_networks
Save and close the file. Start squid proxy server:
# chkconfig squid on
# /etc/init.d/squid start
Output:
init_cache_dir /var/spool/squid... Starting squid: . [ OK ] Verify port 3128 is open:
# netstat -tulpn | grep 3128
Output:
tcp 0 0 0.0.0.0:3128 0.0.0.0:* LISTEN 20653/(squid) Open TCP port 3128 Finally make sure iptables is allowing to access squid proxy server. Just open /etc/sysconfig/iptables file:
# vi /etc/sysconfig/iptables
Append configuration:
-A RH-Firewall-1-INPUT -m state --state NEW,ESTABLISHED,RELATED -m tcp -p tcp --dport 3128 -j ACCEPT
Restart iptables based firewall:
# /etc/init.d/iptables restart
Output:
Flushing firewall rules: [ OK ] Setting chains to policy ACCEPT: filter [ OK ] Unloading iptables modules: [ OK ] Applying iptables firewall rules: [ OK ] Loading additional iptables modules: ip_conntrack_netbios_n[ OK ] Client configuration Open a webbrowser > Tools > Internet option > Network settings > and setup Squid server IP address and port # 3128.
See also You may find our previous squid tips useful:
Nov 26, 2007 | Computers & Internet
Yahoo Messenger Logo
659 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
