I have a vulcan oil heater that has a timer, however, I do not have instructions on how to use the timer can you help?
  • catherine425 Jul 16, 2009
    The vulcan heater has model number 4800045 and the timer is above to on/off switches which can be turned on independently. It is about 1" in diameter with a white center with an arrow on it. It has a red plastic circle around it and this inturn has a dark grey cirle of segmented plastic. Beside the button is a picture of a hand and a clock.
    I hope the explanation helps.
    Scholar:
  • 83 Answers
Hi
What timer is it?
Steve
Posted on Jul 14, 2009
  • Steve Smith
    Steve Smith Jul 16, 2009
    Thanks for the details they are indeed a great help.
    I hope this explanation helps you.
    The two switches are for heating and hot water (not sure which is which? turn one on, and turn your room thermostat up, listen to the pump is it running?If it isn't, then that is your hot water switch, turn the other one on and the pump should run, you cannot have the heating on without the HW, but you can have the HW on by itself)
    The hand sign means 'Manual override'
    The clock sign means 'Timed settings', this is explained below......
    The ring of segmented plastic in a circle are time setting pins around a clock face, they usually are in increments of 10 or 15 minutes.
    They can be pushed inward to the centre of the face or outward, this will allow the user to have a 'TIMED' selection for heating & hot water. Because each timer varies it could mean this:
    Pushed IN = OFF
    Pushed OUT = ON
    ----- or -----
    Pushed IN = ON
    Pushed OUT = OFF
    Either way you will need to make sure you have timed segments in or out for it to work correctly, example:
    On 8am Off 10am all segments between these times will need to be in or out (depending on which timer) to allow the boiler to come on.
    I'm sorry it's such a long winded explanation, i hope this helps?
    If not let me know.
    Take Care
    Steve :)
  • Dmitry Green
    Dmitry Green Sep 26, 2011
    Hay there, This was VERY helpful. Thank you
Where can i get heating filter (ceremic?) replacement parts for an old vulcan heater?
Do you know the model heater?
Can you post photo of the filter?
I have some filters for Vulcan oil heaters
Aug 18, 2011 | Vulcan AUW230A Heater
Trouble starting an vulcan oil heater
Are you able to post a picture/photo of the heater. I may be able to give lighting instruction.
where are you, I'm in Adelaide SA
Oct 25, 2017 | Vulcan AUW230A Heater
Require replacement glass for old vulcan oil heater
Hi ddsalm,
Did you ever recieve an answer to this?
Jun 22, 2010 | Heating & Cooling
Vulcan 11 fin coil oil heater. it just stopped working.
The heater should not have been affected by the what the maid had done. Turn off the power to the heater and let set for a bit, Check your thermostar settins, turn all the way dow and back up to what you want set the timer and give it a chance to heat up again. There might be a reset buttun somewhere so look around. I bet its cold in Austrailia right now.. Good luck-Ned
Jun 12, 2009 | Heating & Cooling
Instruction manual
This site should help you with the Vulcan and other items in your home.
http://www.aga.asn.au/uploads/148/05_2006.pdf
Mar 01, 2009 | Water Heaters
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Vulcan oil heater
Regarding the wiring on my ancient Vulcan oil heater...I have only just received a wiring diagram (dated January 1969), which I am just about to get stuck in to. I hope that I can follow it (the drawing looks like the last copy of something that's been copied 1,000 times before on one of those old Roneo, wet ink, wind-it-by-hand copiers). The drawing came from a Vulcan agent on the very far side of Adelaide. Here's hoping. Ooroo, John. .
May 27, 2008 | Heating & Cooling
Vulcan Oil Heater
move the collar away from the orifice for a blue flame. too little air causes incomplete combustion so you get the yellow tinging
May 18, 2008 | Heating & Cooling
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
