Question about Acer Computers & Internet
Aspire ZG5 Won't Complete Boot Process
This machine attempts to boot, however, it gets to the "Window XP" screen and immediately returns an error stating "Insufficient Resources to continue (Refers to LSASS.EXE) error in particular.
I've tried the Alt + F10 solution mentioned on a few sites but that doesn't give me any response at all.
I've also tried F8'ing to try booting in Safe Mode, Safe Mode with Networking, etc. without success. If I attempt to load in Safe Mode in any way, shape or form it returns a STOP: "C000021a - Fatal System Error" - Blue Screen of Death.
The machine is an Aspire One Series, Model ZG5
    President:
  • 846 Answers
Hello Dzaitz,
A description of the error message: http://aumha.org/a/stop.php#0x21a
Basically, Windows' security has been compromised - so it won't work until you fix the security issue.
The "0xc0000005" part means that the error occurred in your memory. Most likely this was either caused by the power outage or malware. If the power outage caused it, there may be other damage that isn't obvious at this point.
Since you can't boot into Windows, your choices are a bit limited.
First, I'd suggest that you run this free, bootable memory diagnostic: http://www.memtest86.com/
As a "just to be sure" measure, I'd also run a free, bootable hard drive diagnostic (available at the support website for the manufacturer of your hard drive).
If you pass those 2 tests, then I'd suggest a repair installation of Windows XP. If you have Internet Explorer 7 installed, read this first: http://support.microsoft.com/?kbid=917964. Then the instructions for the repair install are located here: http://www.michaelstevenstech.com/XPrepairinstall.htm
Post back with any more questions or comments for additional assistance. Thank you for choosing Fixya!
Posted on Jul 14, 2009
Aspire zg5
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Jan 21, 2013 | Acer Aspire 5720-6661 Notebook PC
Acer aspire one model zg5 is in a loop of erecovery management and gives error message cannot format the object drive
If you mean laptop is in boot loop ?
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Boot in safe mode or the operating system equivalent.
Windows, Unix/Linux and Mac operating system have a mode that will load the minimum software needed to boot.
This is a standard approach in troubleshooting, as it only supports the minimum hardware needed to complete the boot into the operating system.
Once you are logged into the computer, device drivers can be updated, software removed and so forth.
To boot into safe mode in Windows, hit the "F8" key when the computer first starts up to get a submenu.
From there select a boot option. Many choose "Safe mode with command prompt" as this will go line by line through the boot process, allowing you to isolate where the problem might be.
To boot into a different run level in Unix/Linux, it depends on the version of Unix/Linux, but most have the option of a "recovery mode."
During boot hit the "Esc" or "E" key and select the mode appropriate such as "drop to root shell," etc.
If you have the ability to get into command shell, enter into run level 1 (single user mode) by typing in "init 1."
To start in safe boot on a Macintosh laptop, hold the "Shift" key as it boots up.
This forces a disk check and loads minimal software in efforts to complete the boot process, much like the other operating system's "safe modes."
Check to see if your laptop is overheating.
Laptops have a greater likelihood of overheating than desktops.
Either touch the laptop or download an application such as Mobile Meter to check laptop temperature.
If it is running hot, try using canned air to clear out of vents, etc.
Also, elevating the laptop off of its resting surface allows greater airflow in and out of the laptop
hope this helps
Nov 27, 2012 | Acer Aspire One PC Notebook
Acer aspire one zg5 - ntldr missing. Can you help and how much is the cost. Thanks
have an acer aspire one zg5 ntldr missing and computer has no cd drive and i dont have the xp cd -rom how can i install then to get my computer back working. please someone help me
Oct 20, 2010 | Acer Aspire One Netbook
Hi, I have a Acer Aspire One (mdl ZG5) computer that was locking up, I attempted to format and reload the defaul system config from the hidden disk partition. The process started and then I received the...
Go to the Acer web site Support and Drivers, put your model number in, your operating system and order a DVD with a factory image for your Aspire One. It may cost you, but maybe not. Next order on optical drive that runs on two usb ports from eBay. I have one that costed $50 with shipping or maybe a local tech has one.
Oct 14, 2010 | Computers & Internet
Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Jul 16, 2010 | Acer Aspire One PC Notebook
Failure to bootup
This message means that the computer could not find the MBR (master boot record) & the most likely cause is a hard disk failure. To prove this obtain an installation disk of an operationg system, say Windows XP, place the disk in the drive, and while its booting up, press F2. From the menu set the boot order to... 1. CD rom drive. Save and exit. The machine will now begin to install the operating system to your hard drive. If you get the same message again, you have a hard drive failure and it will have to be rep-laced.
Apr 05, 2010 | Acer Aspire 3680 Laptop
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Acer Aspire 5920 problem
Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
WARNING:
This will erase everything you had stored on the machine!! ie data files, pictures etc...
Apr 12, 2009 | Computers & Internet
Laptop won' boot up.
The blue screen means the system is experiencing a fatal error... a error from which it cant recover.... so while booting press f8 and boot using safe mode... then analyse the startup programs of your system using Start->Run and then typing msconfig in the window that appears and then going to the startup tab... one of your latest installed program might be misfunctioning....
Nov 19, 2008 | Compaq Presario Notebook
Computers & Internet Logo
651 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
