Question about Fuji FinePix F480 Digital Camera
My finepix f480 says !ZOOM ERROR on power up and then powers off.. i have tried recharging the battery but that does not help.. is there anything else that i should try...please help
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
FinePix F480. Zoom keeps coming out at an angle and jamming so that it won't return into casing.This gives 'Zoom Errors.'
The lens needs to be replaced, or if you can try and SNAP the lens back towards center so it's not at an angle you might be able to fix it. Most likely not though, and you will have to replace the lens.
Thomas
Sep 12, 2011 | Fuji FinePix F480 Digital Camera
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
When i turn on the camera fuji f480 digital camers it shows me zoom error on screen
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2010 | Fuji FinePix A400 Digital Camera
I have a finepix digital camera 205.......It tells me I have a zoom error lense...could you help with this Lamar Oglesby
If you have recently dropped the camera you may have damaged the camera tube (housing) or knocked the zoom mechanism off its track -- both are problems that require professional repair. Otherwise, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera.
Oct 12, 2009 | Fuji FinePix S304 Digital Camera
My finepix f480 says !ZOOM ERROR on power up and switches off. Any suggestions as to whats wrong?
Does the lens retract and extend fully? Because of the design of the lens It is possible that the internal lens has jammed or is damaged. click on my profile and email me and I may be able to help
Jun 04, 2009 | Fuji FinePix F480 Digital Camera
Zoom Error for Fujifilm FinePix F480...Lens not contracting
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Feb 26, 2009 | Fuji FinePix F480 Digital Camera
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Dec 26, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Finepix 1400 won't switch on
I read Something Similuar where This Individual Recharged The Batteries And Then Somehow Rebooted His Comp And The Camera Then began To Respond?
Sep 04, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Fuji FinePix F480 Digital Camera Logo
117 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
