Question about Nokia 7610
Autolock on start up,and can`t unlock any more.I try everything to do...press all the buttons ...but nothing
    Problem Solver:
  • 14 Answers
You must have installed a cracked software or viewed messages that contained virus .
If u have GPRS enabled on ur phone 1st call your service provider and ask him to disable it telling your phone condition .
Here is your solution .::
http://forum.gsmhosting.com/vbb/showthread.php?t=163125
Download and install the software on your phone . it wil enable to manually unlock it . Bye .
Posted on Jul 14, 2009
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
My 2001 ford focus keeps locking. The power locks automatically lock as soon as I unlock them, barely enough time to open door.
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Feb 18, 2015 | 2001 Ford Focus
Central locking 53 vivaro
I don't know if this will help in your situation, but on my Toyota Sienna minivan, the doors autolock after a few minutes if I use the remote to unlock it and no door was opened. I think the user manual has a way to change that setting, but I like the feature so I never tried to change it. (I keep my remote on my belt, so if I accidentally unlock the van by bumping into something that presses the button, it locks up again.)
If I want to unlock it and keep it unlocked, I press the unlock button on the remote and then press the button that opens the automatic side door, and then shut the door again so the van will stay unlocked.
If your van's users manual doesn't have a way to disable the autolock feature, you can probably get the dealer to do it. If you don't have a manual you can probably find one online so you don't have to pay a dealer the full price.
Mar 30, 2017 | Locks & Locksmithing
I have a remote but my tv is on child lock and it saysplease unlock.i don't know what to do .I've tried pressibg other buttons nothing seems to work.
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Jan 09, 2011 | Philips Magnavox 20MS3442 20" TV
I have a Nokia E71x that I've been working on and all seems kosher except I am unable to unlock the unit. When I am instructed to hit the functions key after hitting the unlock button nothing happens. I...
It is not lightening fast. It should be done in two seconds after you press unlock.
To permanently unlock it you must go to Menu->Tools->Settings->General->Security->Phone and SIM Card->Keypad Autolock Period. Here you must disable it. Then your phones keyboard will not lock up automatically.
I hope it works. I have told you the sequence from my E71.
Nov 23, 2010 | Nokia Cell Phones
On my remote the unlock is the only thing that works. my lock and remote start doesnt work. everything used to work before i got my transmission fixed and when i got it back nothing worked and i have been...
You could try reprogramming the remote: ignition on, press and release programming switch 3 times, you will hear one chirp( channel 1),press the lock button, press and release the switch 1 time ( two chirps, channel 2), press the unlock button, press and release switch 1 time ( three chirps) press green remote start button,press and release switch 1 time ( 4 chirps) press option button. Turn ignition off. test. If this doesn't work, try disconnecting the unit's power for about ten seconds, then reconnect and test.
Sep 30, 2010 | Car APS997A Two-Way Remote Start and...
Need to find a way to disarm alarm for Ford Contour Sport, 1996. Also it will not start
Many Ford trucks, vans and suvs use PATs (passive anti-theft) keys. These keys prevent someone from copying your key to a blank and using the blank. There is a small chip in the key which the vehicle must recognize before it will start.
PATS is Ford Motor Company's passive anti theft system. In 1996 it started showing up on select models of Ford and Lincoln Mercury vehicles. The keys for these vehicles have a tiny radio frequency transponder imbedded in the plastic Head.
pats_key.gifWhen you attempt to start the vehicle, the onboard computer sends out a RF signal that is picked up by the transponder in the key. The transponder then returns a unique RF signal to the vehicle's computer, giving it the ok for the vehicle to start and continue to run. This all happens in less than a second, and is completely transparent to the vehicle operator. It is a very effective system that does its job without the vehicle owner having to think about it, or modify his / her usual routine.
The PATs key is used on the following Ford family trucks and SUVS:
1998-up F-150
1998-up Expedition
2000-up Excursion
1998-up Explorer
1998-up Ranger
1998-up Lincoln Navigator
1998-up Mercury Mountaineer
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system.
Hope this help you (remember comment and rates this).
Apr 04, 2010 | 1996 Ford Contour
How do I de-activate the automatic power door locks? 1998 Ford Expedition Eddie Bauer Edition. (also - same thing happens to the 1995 Lincoln Town Car). Any Suggestions?
here is the instructions,i had to type it out because the picture was too large.Its actually for my 2000 Ford,give it a try because it might work.
Deactivating/activating the autolock feature
Before following the procedure,make sure that the ignition is OFF and all vehicle doors are closed.You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated.If the procedure needs to be repeated,you must wait 30 seconds.
2.Press the power door UNLOCK control three times.
3.Turn the ignition key form ON to OFF.
4.Press the power door UNLOCK control three times.
5.Turn the ignition back to ON,The horn will chirp.
6.Press the UNLOCK control,then press the lock control.The horn will chirp once if autolock was deactivated or twice(one short and one long chirp)if autolock was activated.
7.Turn the ignition to OFF.The horn will chirp once to confirm the procedure is complete...Page 89 of the owners manual
about the Town car,try it on there as well,it wouldnt hurt it,i just dont have the manual for it.
Feb 25, 2010 | 1998 Ford Expedition
Set the combination lock on the driver door of 1999 Ford Explorer
check your car manuel and it should tell you to solve both
Jun 09, 2009 | 1999 Ford Explorer
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Nokia 7610 Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
