Question about First Alert SA302 Dual System Smoke Detector
It is a direct wired smoke alarm and it keeps chirping
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Replace the battery with thew exact model specified.
Posted on Aug 07, 2009
Kidde smoke alarm chirping put new batteries in still chirping . Removed alarm and wires are chirping ,can't Believe it !!!! Has anyone else heard of this ?
It will chirp for up to an hour after the battery is replaced. Also make sure the "new" battery is ok, have gotten bad ones in the past several times.
Feb 24, 2017 | Home
My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
Oct 27, 2016 | Cars & Trucks
How to fix a hard wired smoke alarm that won't stop chirping
you don't say what kind of smoke alarm you have, or what kind of chirping, so i'm assuming it's a once per minute chirp which usually indicates low battery, but can also indicate that the unit has some other problem...if the unit is more than 10 years old you should replace the entire thing (per NFPA72, the national fire code, all smoke ALARMS must be replaced every 10 years)...if this is newer than 10 years, try replacing the 9 volt battery being careful to follow any instructions that may have come with the unit or may be printed on the back, top or sides...good luck.
Oct 16, 2015 | Home
MY ALARM KEEPS CHIRPING. Thought I should change the battery but discovered it's not battery operated!
A chirping smoke detector indicates low battery! Change battery or replace smoke detector!
Aug 15, 2015 | Home
My kidde AC smoke alarm I12020 chirps at night then come daylight it makes no noise
Most "chirping" is indicative of low batteries. Perhaps your smokes are improperly wired through a light switch? As to locating, try using a piece of tape over the sound port to change the sound; with these problems there are often more than one causing it. Check also to see if you have any CO alarms that were plugged into a switched outlet. Most of these also have battery backup. Good luck!
Mar 08, 2013 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
My new Firex 21007581 with a new battery keeps chirping. What is the problem and how do I fix it? Thanks Sal
He said it had a new battery so he already did that and why would you service a $12 throw away smoke alarm? This FIREX he identified is the 4618 and will also chirp while the LED light blinks, chirp is about 30 seconds after blink if the unit itself needs to be replaced because there is something wrong with it as opposed to a different chirp pattern for battieries. If still unerwarrantee FIREX will replace otherwise go buy a new one.
Sep 07, 2011 | Kidde 21007581 120v Firex 4618 Pro Basic...
I just replaced 3 old interconnected Nortron AC 12W smoke alarm with 3 kidde direct wire 120V units- ( no battery back-up) when i turn the AC breaker on- all three Kidde chirp every 10 seconds. I ...
The Kidde website does have a lot of manuals but you need the model number. Try going to this URL, then browse by subject. You'll probably find the answer there.
Jul 24, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Rental mgmt company just installed Kidd 112020/40/80 (don't know which one. It does the same thing the previous smoke alarm did - wakes me up in the middle of the night! It chirps every hour, every 30...
They only chirp for two reasons:
1. The sensor is past its useful life and needs replaced
2. There is a power issue with the battery. Even the ones that are hardwired into the electrical system need a battery.
Jun 23, 2017 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Smoke alarm keeps chirping.
I am having problems seeing if you have any more data besides "smoke alarm keeps chirping." so I will ask; have you tried changing the battery?
Sep 06, 2009 | Kidde 1275 Hardwire Smoke Alarm with Hush...
First Alert SA302 Dual System Smoke Detector Logo
813 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
