Question about Dell Inspiron 1501 Notebook
1501 freeze randomly. put it on cool stand to eliminate overheating, still freezes ie: goes black and has a 1 inch square color lined area.
  • 201 Answers
If you can take out the hard drive
would it still do the same thing
if the hard drive is over 5 years old
chances are you need to replace,
also system restore set back to when it worked good, and reinstall windows before buying new hard drive
Posted on Jul 20, 2009
HOW CAN I INSTAL A TOILET ON A MOBILE HOME FLOOR
I live in a mobile home park. I do all the electrical and plumbing and everything else. You can put an ordinary toilet in. So long as there is a flange. If there is not one you can put one in anywhere you choose. Then underneath you can run the 3 inch line to the main trunk going to the sewer. Don't worry about it freezing being below the insulation. Keep the angle so that it empties fast so there is nothing inside to build up and freeze. If where the toilet used to be has some bad plywood cut out a square to put in a square of new plywood. Measure where the old one was beforehand and mark where you want to put the new 3 1/2 inch hole (usually 12 inches from the framing to center), cut your hole using screws with large heads (maybe even stainless steel) screw down the flange. Using solvent glue the new section to the old section etc.
Oct 19, 2013 | Home
Dell inspiron m5030 freezes and screen goes black
It could be the graphics processor is having troubles. Try updating the graphics drivers.
Jan 18, 2013 | Dell Inspiron M5030 Laptop
IBM R52 Seemingly Random Shutoff and gaming lag.
If you can increase the drams to maximum in your computer?
Mar 03, 2012 | IBM ThinkPad R52 Notebook
My ps3 starts up, freezes, picture messes up, wont start back up
try getting the new 3.01 firmware, since 3.0 had some freezing issues with some games, ..
put the consol in a well ventillated palce, put a regular standing fan near it or buy a usb powered fan to keep it cool
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
Shows colors-lines-then freezes???
I have this problem with my 60 gig, I think its due to overheating, I took it apart and put some Artic Silver Thermal paste on the CPU and GPU and it played for about 6-7 hours but then started again. Could be due to overheating or possibly the GPU is going bad
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
I have a aspire 4520 acer laptop that sometimes freezes up with a white screen and what looks like an equal sign types of lines going through it. kind of in a pattern from one corner to another. it also...
Hi
the freezes and lines is most likely the video card failing, or overheating, or damage from overheating.
Its a common problem with the acer aspires, what can you do about it? Vacuum the dust out form the fan or use canned air to blow it out, there will be a lot of it.
Try one of those cooling pads that goes under it.
depending on how bad the problem is with the video card which in most of these laptops can't be user replaced. Got warranty? It might help or might not help at all. That is generally caused by poor cooling and dust in the fan heat sinks so the air doesn't flow and too much heat being generated by the board and its components eventually damaging the video card or the motherboard.
About the 2nd problem, its mainly caused because of your hand touching the touch-pad try a news paper on top of the touch pad or a usb keyboard and see if that problem goes away.
May 17, 2009 | Acer Aspire 4520-5582 Notebook
My playstation3 keeps freezing and wont let me play some of my g
It is freezing because your playstation is to close to the tv and its getting to hot...it is due to overheating you are having this problem ... so try moving it to another spot....you must take care to keep it properly vented.......
The system is prone to overheating, particularly if you happened to have bought older stock.
One way to deal with this is to stand it vertical, and put a small desk fan behind it.Turn on the fan when you turn on the game. I know it's an annoyance but it is a very simple and effective way to work around the problem.
DO NOT use an intercooler fan or any cooling device that gets power from the playstation. It just makes it worse.
when thermal compound fails it gets overheated so you need to look into this too ...replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your playstation.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360
Try standing it up instead of laying it down and make sure it isn't in a coner. The most common reason for freezing is overheating so put it in a cool (NOT COLD!) place in the open. Don't stack things on it or store a bunch of stuff around it. Hope that helps.
Nov 10, 2008 | Microsoft Xbox 360 Console
Loss of color
1)solder jungle IC,3.58 crystal and surrounding area. 2)Alternately,use heat gun then cool freeze to isolate thermal breakdown.
Jul 31, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Dell Inspiron 1501 Notebook Logo
110 people viewed this question
Alun Cox
