Question about E-Machines Computers & Internet
Ive tried 3 diff hd's all say no os found when i inow there is a os there its a e-machine any suggestions
    Scholar:
  • 56 Answers
A hard drive is where your operating system is located, so did you install the operating system onto each of the three hard drives. And if they were already installed prior to you installing them into your system it still wont work, it will need to be configured for your hardware setup. Put in a hard-drive and install the os from scratch this will get you up and running.
Posted on Jul 14, 2009
My rear end went out in my 99 gmc sierra. And i can not find the part at the junkyard i went to 3 different junkyard
when in trouble replace the whole diff housing for the new 14 bolt diff. from the wreckers.
Mar 24, 2013 | Cars & Trucks
Front diff not disengaging all the way
If you can verify the noise is coming from the front diff, try these two things. Back the actuator out some or completely remove it, only some fluid will leak if driven a short distance. If there is no change, use a pry bar and see how much play there is at the left front axle. Pry between something like the a-arm and the shaft of the axle or the frame and the flange of the axle. If there is excessive play, I've found the clips that hold the side bearings in adjustment sheer off and let the bearings have excessive play leading to bearing failure. The difference in the noise you hear could change because the axle goes from free wheeling to being driven. If the second description fits, all new bearings and seals should fix you up.
Dec 31, 2009 | 2003 GMC Sierra 2500HD
Camcorder wont work with mac os x
Your camera will not work with Mac period. It is a digital camera but is outputting an analog signal. Been there and done that with a TRV camera myself. There are lots of cameras that will work with your G5 Mac. I am now using a Sanyo VPC-HD 100 with my Intel iMac and it works great. Click the link for some supported cameras. This is not all of them. http://support.apple.com/kb/TA20587
Oct 14, 2009 | Computers & Internet
This is a awd it keeps burning up front diffs went through 3 used complete units gear ratio is correct tire size is correct only happens on long trips it is a 2004 mercury mountaineer
have someone inspect the rear diff. ive seen diffs changed to diffrent ones and not change the tag. your problem might be in the back. hope this helps good luck
Sep 19, 2008 | Mercury Mountaineer Cars & Trucks
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Problem installing OS
I think Partition Magic 8 screwed up the hard drive. I suggest, try a different hd, or if you don't have one, go to www.ebay.com and get like a 5 or 10GB hd and try that, cause if it works with a different hd, it proves that Partition Magic 8 screwed up the drive. Anything else, try a new IDE or SATA cable cause sometimes they go bad. try a different OS cd. Anything else I could say is bring it to a local computer store and see what they can do.
Jun 03, 2008 | Dell Inspiron 1501 Notebook
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
Kika633@yahoo .com
you need to reinstall windows, put in floppy boot up disk set the cd to run have your windows cd in tipe d: install
Dec 24, 2007 | E-Machines eMachines Desktop PC
Problem
Hi, It is possible that your anti-virus quarantined suspected files but are required for booting up Windows. You can try: 1. Booting in Safe Mode to check things out; 2. Boot in last known good configuration; 3. Re-install Windows using the "repair" option. Experience has taught me that the safest was re-partitioning, re-formatting and do a complete fresh/clean/new install of the OS. Good luck and kind regards.
Sep 28, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Computers & Internet Logo
79 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
