I found this. Might help you.
http://www.nationaltruckspares.com.au/P_Nissan--UD-FD35-Cabstar-SGH40-Torque-Specification-.aspx?id=1133
SOURCE: Torque spec for flywheel bolt: Isuzu 2.5 diesel engine
normally 110 nueton metres. use nut lock and once you have torqued you will feel if you have to tighten it a bit more.
SOURCE: need cylinder head bolts torque settings for nissan 3.2d
what nissan model do you need the head torques for
SOURCE: cylinder head torque settings for a toyota 1493cc
If you have a vehicle application for the motor you can get a Haynes or Chilton manual from your local auto parts store. They usual run around $30.
SOURCE: head bolt settings
1st - step; - 22 ft./lbs. 2nd - step; - 58 ft./lbs. 3rd - step, loosen all bolts completely; 4th - step; - 22 ft./lbs. 5th - step; - 54 ft./lbs.
SOURCE: whats the torque setting for big end bearing bolt
hi big end bearings are two stage, 25nm leave ten mins, then 49nm cylinder head bolts three stages 20nm leave ten mins, 40nm leave ten mins then 60nm check after 5,000miles hope this helps
