Promble with Ram
Do i need two video cards to run 4 sticks of ram?I have 4 Patrist 1GB pc3200 400MHz & one Ge Force 9500 GT pci-E 2.0 card.But it only reads two GB of ram.or is it two dimm slots for each video card?If i put all four sticks of ram in it only reads 2GB.
  • Computers & ... Master
  • 5,660 Answers
No the problem isn't the ram, or video card, or lack of video cards.
The problem stems from using a 32 bit O/S, (Operating System), like Windows XP Home, or Windows XP Pro. (The 32 bit version of XP Pro. Microsoft made a 64-bit version of Windows XP Pro)
A 32 bit O/S will only 'recognize' UP TO 3.2GB's of ram. (Sometimes up to 3.5GB's)
You need a 64 bit O/S so that your computer will recognize all 4GB's of ram, when it is installed.
32 Bit? 64 Bit? What is all of this? It's kind of hard to explain in a few sentences. I would like to refer you to these links on Wikipedia, to explain 32 bit, and 64 bit further,
A.32-Bit:http://en.wikipedia.org/wiki/32_bit
B.64-Bit:http://en.wikipedia.org/wiki/64-bit
Posted on Jul 14, 2009
What cheap but good video card should i get to run modern warfare 2 on my dell desktop computer
From what I can determine, for you to have the permornace you need for Modern Warfare 2, the following are the recommended computer requirements:
A CPU: 2.4 GHz dual core or better, RAM: 1 GB on XP / 2 GB on Vista and Windows 7 and a
GeForce 9500 GT 1GB memory Graphics board. (this is a PCI Express slot board).
Make sure your Dell has the slot required for the graphics board, if no slot then there is an AGP board, but with 512MB memory that would work good.
Either graphice baord would cost about them same
Recommend, EVGA @ Negeeg.com or Tiger Direct.
Good Luck
Sep 04, 2011 | Nvidia GeForce FX 5500 256 MB, (256 MB)...
How muchupgarade need to play gta 4
you gonna need another 1gb of RAM and a video card 512mb either AGP or PCI this sites has video cards
go to google and search 512mb video cards AGP or PCI
May 19, 2010 | Dell OptiPlex GX260 PC Desktop
I wanna know that is XFX 9800gt supported on intel DG31PR motherboard or any PCI express motherboard ? I also wanna know that is it a good combination of 9800gt DDR3 1gb and DDR2 RAM 2gb?? Please reply me...
nVidea 9800gt is a good card... probably not a question of if the MB will support it as much as if your power supply will. It needs a secondary 6 pin power connection.
Any MB with 16x PCI slow will run the board. The different RAM types on the MB and Video card will nto matter as much as the throughput of the PCI bus...
2GB ram on you main board, hope you are not running anything serious.... I do a fair amount of video with a 9500GT. Quad Core 2.66, 6 GB ram and am looking to upgrade to an I7 with 12GB and a nVidia 250 or better....
Mar 07, 2010 | Pine Technology XFX XFX GeForce 9800 GT...
I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Oct 04, 2009 | Computers & Internet
Ram
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Hank
Jul 14, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Can i paly gta4 with 9500 gf 1 gb 3d xpress card
YES.
Go to this website, chose GTA 4 in the list. It will scan your computer and tell you if it will run this game.
http://www.systemrequirementslab.com/referrer/srtest
I have a dual core with a PCI-e 9400 GT with 1gb ram onboard and it says I can run this game.
May 05, 2009 | Computers & Internet
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Graphics card
Then you probably need a new graphics card.. JTF requires these at a minimum to play:
Minimum System Specifications
  • Windows 2000/XP Home or Professional/x64
  • Intel Pentium 4 2 GHz or AMD Athlon XP 2000+
  • NVIDIA GeForce 4 (non-MX) or ATI Radeon 9500, DirectX 9.0c compliant videocard with 128 MB RAM
  • 512 MB RAM
  • 3 GB of uncompressed hard drive space
  • DirectX 9.0c compatible sound card
  • DirectX 9.0c (included)
  • 4x CD/DVD-ROM drive
  • Microsoft-compatible mouse and keyboard
  • 56 kbit/s dial-up modem for online play; 10 Mbit/s for LAN play
Oct 17, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Asus p5rd1-vm motherboard problem of graphics card
Hi shuter. Your Asus P5RD1-VM has an integrated video adapter ATI® Radeon 9600 GPU. You need to enter your bios & change the video start up order. Pg.2-22 in your manual.
Configuration options: [IGD] [PEG/IGD] [PCI/IGD]
Boot Graphics Adapter Priority [PEG/IGD]
Save & exit. Check system at boot up for correct memory count.
Thanks for using FixYa & if you need more help just re-post here. Have a good one!
please vote...
Feb 29, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
