Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epson CX3810 my pc says my printer has a paper jam and won't clear. I have two identical models and both have the same issue. The second is a warranty replacement for the firest and now both are out of warranty. Any ideas?
The printer has new ink cartridges in it and new paper, but it will not print or even run the paper through.
Posted on Aug 26, 2009
    Genius:
  • 1,601 Answers
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Had paper jam, took several attempts to clear. I now cannot get my printer to power up?
Issue On Paper Tray... also reset you spool Tray Memory System ..Unplug Printer from PC tun off Printer ..Open Back Cover then clean Paper Jam Then Re plug printer then turn it On ...Then Try to Print Something
Oct 07, 2010 | Epson Stylus CX9400 Photo Printer
Printer says paper is jammed but is lying flat. Turned it off and back on and paper ejected. I tried again but same thing happens. (Epson stylus)
sounds like you still have paper stuck in the rollers.
get a flashlight, and look carefully, teeth by teeth.
good luck
Apr 06, 2010 | Epson Stylus CX3810 All-In-One InkJet...
Epson RX520 - Paper jam - how do I open and get paper out? Restarting machine and pressing 'Clear' does not get it out.
*** I'll be more than happy to help you on that. just a clarification. .maybe its RX620, because there's no rx520.
anyways, trouble shooting goes like this...
turn off the printer first. lift the scanner, you should see the part where you install the inks, if you're there, check for paper jam or any foreign object, take it out then turn the printer back on. if paper jam is still showing, the printer is already having a hardware failure. i gues this printer is more than a year, if thats the case, it may be out of warranty for epson, bec, theyre warranty is for a year only,
good luck
Feb 15, 2010 | Epson Printer
Had a paper jam when cleared and turned back on keeps showing Error and lights flashing?
Two possibilities - First, the jam is not completely cleared. Check to make sure there are no small bits of paper blocking a sensor.
Second possibility. You don't say what model printer you have, but some need to be reset after a jam. Check your manual to see if your printer is one of them. If so, just follow the directions. Another option is simply to turn the printer off for about 30 seconds and then turn it back on. This does an automatic reset.
Oct 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I've got an epson stylus c44ux printer. It recently had a paper jam and now the red light is on constantly. There seems to be no way to reset it. I've replaced both ink cartridges, cleared all paper from...
You may try to do the following:
1. Turn the printer off and unplug it from the power source.
2. Remove any obstruction or any foreign material inside.
3. Check if the inks are clicked into place on their correct slot and and cartridge cover is closed properly.
4. Turn the printer on.
If same issue persists, it might be a hardware failure. Or you might want to contact Epson for further assistance and/or troubleshooting for that matter.
Jan 01, 2009 | Epson Stylus C44UX InkJet Printer
CX3810 printer will not print
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
Nov 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
"not ready to print" message
I just recently had the identical problem. Go to "start," click on "printers and faxes"; right-click on the icon (or copy for it) for your printer; select from the popup menu, "default printer." This will put a check mark by the printer icon, and possibly simultaneously remove the check mark from another icon that was a deadend. I encountered this problem when I replaced my paper-jammed epson stylus CX3810 inkjet printer with another almost identical printer that had been abandoned by an acquaintance. [He had abandoned it because his ink nozzles (except black ink) had clogged up. I was grateful for it despite the seemingly irreversibly clogged nozzles.] I think printer manufacturers should work on more user-friendly designs that allow easier repair of mechanical problems like paper jams!
Mar 28, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Epson 3810
look in and around where the paper is fed into.there maybe a small piece of paper stuck somewhere inside. if you do see something, unplug the machine and try to pull it out with a pair of needle nose pliers. if you do get the obstruction out, try feeding the paper back in and see if it now works.
good luck.
wg
Feb 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Paper feed problem
well it´s not supposed to do that - it is clearly a hardware issue
check your warranty status with the vendor
Dec 26, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus  CX3810 All-In-One InkJet Printer Logo
276 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
