Question about Motorola Mobility Motopure H12 Bluetooth Headset
H12 No Sound
I have the exact same problem. The H12 is charged and paired, but now I have no sound. Please help.
Even though my H12 is paired and it will dial the last call, I do not have any sound. I do not even hear the initial tone when i turn it on.
unpair it from your device and pair it again or try restarting the device your connecting it too and unpair and pair it again. Hope this works!
Sep 10, 2011 | Motorola Mobility Motopure H12 Bluetooth...
Need pairing mode for H12 .to sync to a new device What is K1 etc.?
The easiest way to find this information out would be to go on the Motorola interactive bluetooth pairing simulator: Motorola pairing simulator
This will ask what headset you have, and I've noticed the H12 is in a section titled "existing products", it's just a fraction down from the top of the webpage when it opens.
You will then be asked which phone make and model you have.
This will then take you to a very helpful interactive page which will walk you through the pairing process step by step.
I hope this helps.
Warm regards and a Merry christmas.
Mike
Dec 23, 2010 | Motorola Mobility Motopure H12 Bluetooth...
PIARING MY MOTOROLA RAZOR V3 WITH MY MOTOPURE H12
turn your bluetooth on and on your phone go to bluetooh or settings(if not under bluetooth) and select trusted devices or pair devices, then on the left or right corner it will say (search) once you have found your bluetooth it will say(motopure h12) select and then it will say pair device and you put in the code that came and your instructions and your good to go.
Feb 27, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Bluetooth Headset MOTOPURE H12
My H12 manual has the passcode as 4 zero's for most phones.
Feb 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motopure H12 will not pair.
have you tried charging ur h12 headset until its full? if so then the internal battery inside the headset is probably getting old or dying out, suggest you bring it to ur nearest local Motorola store for details on repairing the headset.
Feb 03, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Bluetooth headset H12 pairing code
I just kepted trying the 0000 and it finally worked. Thanks for trying to help me. Debra
Jan 14, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
H12 able to pair but no sound
Yes I would think that the unit is bad. If it is paire and you see volume level then there should be sound.
Dec 03, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Cant pair H12 Headset with PC
I don't think the h12 will do stereo bluetooth. Windows may have a setting to go mono and then it may work. Poke around the Sound and Audio settings in the Control Panel to change it to mono. Good luck
Nov 21, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Mobility Motopure H12 Bluetooth Headset Logo
568 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
