Question about Saitek Eclipse II
Boot Up Problem with Eclipse II Keyboard
I recently purchased the Eclipse II keyboard and like it very much
When I attempt to press "Esc" F12 or F2 on reboot to enter the computer
Bios, setup, ect., it will not do so. The lights on the keyboard go off,
then come back on and it ignores the commands. I had to connect my old
Dell keyboard to access the settings. Is it because the keyboard is USB
or is it something else? Is there a update or anything to fix this
problem? It is very, very annoying to have to dig out an old keyboard
just to access these settings. I dread my next hard drive format and
Windows installation due to this problem. Please help.
If you have a newer system you can enable USB legacy support via bios and your new keyboard should work fine, otherwise, your keyboard will only work once the operating system is booted up.
Posted on Mar 28, 2008
Do i have a faulty "A" key or a faulty keyboard?
You will need to purchase a keyboard replacement. Thanks for using FixYa! You can purchase them rather cheap at
Feb 06, 2012 | Dell Inspiron Computers & Internet
Loud fast beeps on boot.( Toshiba Qosimo F45 )
Looks indeed as if the TAB key was stuck or malfunctioning. The most common cause for such behavior is a liquid spilled on the keyboard, a bit of which got between the layers of the keyboard membrane films and causes intermittent semi-short between conductive areas.
A trace of liquid caught between plastic films is hard to get rid of, as it practically sealed and doesn't evaporate.
If it doesn't go away, you may need to replace the keyboard, which is not very expensive fortunately,
Jul 08, 2010 | Toshiba Computers & Internet
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
System wont boot
Disconnect all devices except keyboard and mouse and master cd or DVD. unplug then hit power button. Plug back in. Hit power and hopefully you get to BIOS. If you do make sure you save the BIOS before you leave to start OS. Keep me informed and I'll keep checking your listing to see if its working or not.
Sep 24, 2009 | Computers & Internet
Gateway 1150 won't boot to CD upon pressing Esc key.
hmmm...unfortunately that is now a primary function key...
you can press F2, enter bios set up and make cd first boot option(follow instructions)..
then insert recovery cd, and restart system..
Nov 23, 2008 | Gateway 2520796 Keyboard
Ctrl + Space
maybe u got a bad one?
Feb 25, 2008 | Saitek Eclipse II
Saitek Eclipse II Lighted Keyboard
Changing the default colour involves a little dis-mantling. remove the screws from the back of the board. Carefully remove the rubber feet inserts too as there are 4 more screws under there. Now remove the top section of the keyboard (the bit with the keys) Lay the board down flat and you will notice where the usb cable comes in a circuit board. this has a connector with 4 wires attached to it on the left hand side. the wires are coloured red, grey, blue and black. Remove the connector and swap over the Blue and Red wires. Re assemble the keyboard after reattaching the connector to the circuit board being VERY careful not to overtighten the screws. Now at boot up the keyboard will by default be red.
Sep 15, 2007 | Saitek Eclipse II
Another "Won't Boot"
First Press all the keys on the keyboard (computer on or off)a sweeping motion accross all keys will do, A stuck key can prevent windows from booting (seen as a keyboard error). it is also possible that your keyboard connector has come loose, check the keyboard connector (you will need to remove the facia above the keyboard and may have to undo a couple of screws to do this). could try to plug in an external keyboard, see if this allows you to bypass issue
Aug 24, 2007 | HP Compaq Presario V2000 Notebook
Saitek Eclipse II Logo
175 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
