Question about Samsung 50" Slim-Depth DLP HDTV
DLP 5063WX. Sound but no picture. Screen Black. Just replaced Ballast. Problem still there..Flashing green Timer/Lamp..Cycles a few times and turns itself off. Any suggestions?
  • 304 Answers
Is the Lamp ok? Go to the rear of the set and turn on the set with your remote while looking at the vent slats. If you can see a bright light through the vent slats then your Lamp is working. If the lamp is on and you have sound and no pix, then the Digital bd is in what we call "Video Mute" and will have to be replaced. Also make sure that the Lamp Door is installed and the screws are tight.
Posted on Jul 16, 2009
  • Samsung Master
  • 5,138 Answers
If you havent replaced the Lamp replace it.
Posted on Sep 25, 2009
    Problem Solver:
  • 15 Answers
Mine went out within a year of replacing the color wheel. Replace the Lamp. It will fix your problem. The only other issue would be a failing chipboard. Forget doing a tech replacement. You can DIY very easily and only pay for the lamp itself. The lamp average cost is between $55-115. Good range is $73. check amazon. There is a company I ordered mine from located in San Diego. Company is really great:
http://www.discount-merchant.com/SearchResults.asp?Search=samsung+5063+lamp
Posted on Feb 27, 2013
Yep, whenever the TV keeps going black or even turning itself off, it's time to replace the lamp! I have gone through 4 lamps in 4.5 years. So expect it annually... Oh, and at 4.5 years old (out of warranty of course) I had to have the whole "brain" replaced which set me back $350-400. The Circuit City warranty maintenance tech gave everyone his phone#, before they went out of business. My tech replaces lamps for $150.
Posted on Nov 30, 2009
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
I have sound but no picture. The screen is black. I replaced the lamp and it's still not working. This happened a few years ago. I replaced the lamp and the tv came right on, but not this time. Any...
DLP tvs alots of times the board that call the Ballast board is also dead too,beside the tv projection lamp.The Ballast board only job is to ignite the projection lamp.
Mar 02, 2011 | Gateway DLP56TV 56" Rear Projection...
Samsung HLP 4663w dlp-hdtv replaced lamp and ballast, still not working. lamp/standbytemp and timer all flashing. i get no clicking on ballast, upon power up all i hear is low fan or vibration sound which...
If the capacitor on the ballast was puffed up or blown up you have to replace the lamp, ballast & SMPS at the same time. But if the ballast is not trying to fire the lamp it sounds like the color wheel is not coming up to speed. If this is the case, the set will not turn on.
Sep 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
I have a model 52HM95 installed new bulb worked for awhile 2days when i turned it back on got sound no picture then it kept turning on and off now all i get is the green and red lights flashing on and...
It looks like you have a weak ballast issue this is a common problem with DLP sets, this ballast board starts to wear out with time and use the lamp needs at least 150w 12vdc to turn on and if your ballast board only feeds it 120w or 130w it will not be able to turn on another thing that this ballast due is gather enough energy ( 150w ) to turn on the lamp then get weak again( 120w ) and can't maintain the lamp on and turn back off
Sep 13, 2010 | Toshiba 52HM95 52" HDTV Projection...
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
if the remove the lamp and you have seen it is busted try replacing it with a new if it is not check the ballast.
Aug 11, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 50" Slim-Depth DLP HDTV Logo
310 people viewed this question
Henry  Thomas
Henry Thomas
