Question about E-Machines eMachines Desktop PC
Cyclic redundancy error
I am getting cyclic redumdancy error at the time of copying data on pendrive Even after formatting after some time this message appers on 1GB pendrive while copying data. What is the solution.?
    Problem Solver:
  • 11 Answers
Run a disk check on the pendrive to flag and correct any bad areas, try the copy again, and if you still get the message, run a check on the drive from which you're copying as well. (If this is Windows and you're copying from the "C" drive, you'll need to schedule the check at reboot, which the utility will prompt you for. To do the disk error checks (in Windows), right-click on the disk in the "My Computer" view and click on "Properties". That'll bring up a tabbed dialog --- click on the "Tools" tab, then click on "Check Now" under the "Error Checking" area. Enable all checkboxes, then click "Start". If prompted, click "Yes" or "OK" to schedule a check at reboot.
Posted on Jul 15, 2009
    Scholar:
  • 56 Answers
In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear,
All of the above is true, didnt write it myself copied it from a good friends post. It is probably the data itself that is corrupted. Doesnt mean the data is gone. Try running a disk defrag, if that doesnt work try copying it to a cd/dvd and see if you get the same error. If you dont, flash your bios. This should explain your problem, if it doesnt follow up with me, email address is kustom42 at gmail.com.
Posted on Jul 14, 2009
Data error cyclic redundancy check
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Cyclic redundancy error when copying backed up files into Itunes
Files with cyclic redundancy errors means these files are corrupted and cannot be copied. Since you cannot copy these files from your faulty hard disk again then these songs are lost and you need to download them again.
Nov 27, 2012 | Apple iTunes
I am unable to format my pendrive ,message comes "windows was unable to format " also shows error of cyclic redundancy error,so please tell me how i will repair it?
it could be a HW failure....try doing it in another machine....
or do a low level format using a DOS utility called KILLDISK
get it from google
Sep 25, 2010 | Computers & Internet
When i install,bluetooth setup in my desktop that time a information came like cyclic redundancy check problem.
Cyclic Redundancy Error comes when the source device like a computer calculates data and add the size of the information and sends it to the destination device. The destination device sees the size of the information and recalculate the size of the information and compare the two if they do not match the cyclic redundancy problem is reported because the information data has gone corrupt during the transit from the source to destination device. It can be a wrong configuration or packet collision. If it is due to packet collision the error can be over come by resending data multiple times.
Sep 11, 2010 | Computers & Internet
When i trying to copy anything to my 2 gb memory card it says "cannot copy file data error cyclic redundancy check"
Try to format the usb device by right clicking on the drive and then selecting format option. Try to copy your data after formating is finished and the device is ready to use.
The solution is with the assumption that you are using a Windows Machine.
Jul 27, 2010 | Computers & Internet
When I try to copy Outlook data from the DVD to HDD it is getting an error '' cannot copy Outlook: data error (cyclic redundancy check) kindly do the needful to resolve the issue. Thanks & Regards...
CRC error indicates bad sectors, try one thing:
open the data file from outlook and from there create a new pst on the destination and copy the mails, you may loose some mails but the rest of the data will be safe
Jul 23, 2009 | Computers & Internet
Data error cyclic redundancy check. I have windows XP.How do I fix this?
Your disc is scratched. That error will come up when it happens. Try to clean your disc. get all the fingerprints off of it.
May 24, 2009 | E-Machines eMachines Desktop PC
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
400 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
