Question about Husqvarna Viking 1
Viking sewing machine model 6430 will only sew backwards
I have a Viking sewing machine model 6430 and it will only sew backwards The backstitch button will not work on returning to forward stitching. Is there a way to fix this problem?
Kind regards,
Joan
    Sniper:
  • 52 Answers
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
  • 46 Answers
Bbragg77 is mostly correct. It is not the camstack. Although they will crack, but that is all together another problem. It is the stitch length/reverse mech. You can manually work it back and forth to free it and I like to use break cleaner to get it free then re lubricate. A good service shop can put you back in business. And yes Viking does not support 6000 series machines any longer.
Posted on Jul 25, 2009
How do I center the needle on a Viking 6430; there is no eccentric adjustment on the needle bar frame on this model.
Am having difficulty finding information on this machine.
http://husqvarna-viking-service-repair.blogspot.com/p/husqvarna-viking-service-manual-models.html
http://sewingnz.blogspot.com/2010/09/husqvarna-viking-service-manual.html
Perhaps this machine is a left-needle position machine, ie the normal straight stitch sewing position is on the left, not centered. There are quite a few machines out there with this feature, Necchi is another. The needle only swings right when a decorative or zig-zag stitch is selected.
Stitches and Seams Review Viking 6010 Sewing Machine (See #3 under Dislikes.)
If it is actually a center-needle position machine, it is probably out of alignment. There is most likely an adjustment. For more help, you can also join some Viking user groups on Yahoo. Most members are very dedicated to the brand and would be able to provide some very helpful advice.
Nov 28, 2015 | Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Viking 6430 bobbin winder post won't pop out
if the bobbin winder spindle won't move at all, it could be damaged, it would be a good idea to have the machine checked.
Aug 21, 2013 | Husqvarna Viking 1
What do u oil on 6030 viking
some sewing machine can be oiled some are self oiling, it would
be a good idea to contact viking sewing machine customer service
and ask them, here is a link for a manual to see if it has the
information you need
http://www.sewingpartsonline.com/instruction-manual-viking-6030-6270-6430.aspx
Nov 28, 2012 | Sewing Machines
How to clean a Viking 6430 sewing machine
You can find extensive information here: http://stitchesandseams.blogspot.com/2010/04/review-viking-6010-sewing-machine.html.
You really should get a manual. It will give you all the details about cleaning your machine. You start by opening anything you can (be careful with the screws and plates - I keep a magnet for holding these while I clean) Take a pipe cleaner and/or a small sewing machine brush and get out any lint. This is where you first need your manual. It will tell you how to clean the bobbing case. After all lint is removed, you will need to oil it in certain spots...again, you need the manual for this. Always use sewing machine oil in your machine. It is different than other oils. You can download your manual here: http://gotoes.org/sales/VikingSewingMachineManuals/ViewInfo.pl?Viking=1&Sewing_Machine_Model=6430. I think they charge $7 for it.
Jul 08, 2012 | Husqvarna Sewing Machines
Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Jan 16, 2009 | Husqvarna Viking 1
Reverse sewing button stuck HELP!!
The mechanism requires lubrication from the back, would be best to have machine serviced.
Jun 30, 2008 | Husqvarna Viking 1
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
2,454 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
