Kitchen Ranges Logo
A
Anonymous Posted on Nov 23, 2015
Why won't big oven door unlatch?
Tried using self clean cycle. No response. Turned off breaker at panel for 20 minutes. Tied self clean again. Still no respone. Few hours later preheated oven to heat frozen pie. Went to put pie in oven and door had latched closed. Turned oven off. All kinds of clicking and creeping sounds happened while oven cooled off. The door is still latched closed.
David Smith
Level 2:
Scholar:
  • Expert 120 Answers
  • Posted on Nov 25, 2015
David Smith
Expert
Level 2:
Scholar:
Answers
120
Questions
Helped
20227
Points
316
Sounds like the lock motor has failed. Lots of clicking noises and not being able to lock/unlock is normally a good indicator. In some rare circumstances, main control board could be faulty. Look for me on 6ya if you need any more detailed help.
5 Related Answers
A
Anonymous
  • Posted on Feb 16, 2008
SOURCE: VDSC365-6B
ove corse you need to make sure your oven is or has cooled down and turn the breaker off for good measure  I had this problem.  I think the locking unit is jumping gears because i hear a grinding sound when Mine locks.  The way I got mine open was,  Lookalong the top of the oven door.  there are vent slits cut in the top, if you look in them where the latch is you will see the hook that is holding the door shut.  I took a butterknife ( you need something flat and strong because of the angle yu have to hold it at.  take the knife and push the hook to the left.  I will take a few tries but it should pop open.  once it is open and power is restored the latch will retract to its normal position.  hope this helps
Anonymous
  • Posted on Dec 28, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Anonymous
  • 242 Answers
  • Posted on Apr 14, 2009
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
Anonymous
  • Posted on Jul 11, 2009
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Anonymous
  • Posted on Feb 28, 2010
SOURCE: GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! [email protected]
2answers
No power on stove after using self clean oven door is locked and cant be open is there a braker swith somewhere
A self cleaning oven that won't open after the self cleaning cycle is usually the oven has not had time to cool down from the high temperatures of cleaning. You should wait at least an hour to open it. You can also try to unplug the unit or turn of the breaker to the over for at least five minutes. You will then have to reset the clock and then try to move the door lock. If that does not work, you can set the self clean cycle again for but only allow it to work for 15 minutes, then cancel the cycle and let the oven cool and then again try to move the door lock or open the door If that does not work, then the lock will have to be accessed and moved manually to open the door
Some ovens need the door to be manually unlatched before the controls are set to the off position before they can be unlocked.
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
1helpful
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
1helpful
I ran the self-cleaning and the door will not open.
or
1helpful
I cannot unlock my door after self cleaning, it has been several days i pushed the 9 and unlock key but it will not open.
or
How to unlock my door after self cleaning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
I need to get my oven unlocked. The cleaning cycle went haywire
or
4helpful
3answers
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
or
2helpful
Door wil not open after self-cleaning cycle.Code
or
2helpful
Oven door is locked and we can't open. We have tried everything including turning off the circuit breaker several times. HELP please!
or
Top Viking Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
