Question about Sony PEGA KB11 Keyboard
Sony vaio keypad problems
Hi, got similar problem... keys 2,4,0,R,Y,U doesn't work too. I have asked a local technician here in the Philippines and told me that I got to options, first, I replace and buy a new keypad. Second, I use a wireless keypad or the one with usb. The second option is cheaper but not that convenient though.
    Top Expert:
  • Sony Master
  • 46,069 Answers
You have a keypad confused with a keyboard.
Posted on Jan 09, 2018
shaky120
  • 310 Answers
SOURCE: Sony Vaio PCG K115M keyboard problem
Hi, its easy to fix. you have your keyboard layout set to US Layout, ie americans have a couple of keys in reverse from ours. All you have to do is this Windows XP Start, Control Panel, regional & language settings, change all US Settings, in there to UK British, And it will fix your problems :-) if its windows 98/ME ETC start, control panel, Keyboard, and change the US Keyboard setting to UK British, u usually have to set it twice, ie select uk, apply it, then do it again before it changes... If you dont get it sorted will guide u though it just email me.. All the best John auctionscotland@tiscali.co.uk
Posted on Feb 28, 2007
hmerchant110
  • 7191 Answers
SOURCE: sony vaio keypad problems [ model VGN-A517M ]
This may be due to collection of dirt in the keypad. You can clean the keypad by opening it.
Posted on Apr 23, 2009
SOURCE: Hi my sony vaio vgn-sr13gn, shift key does not
A friend of mine has the same problem and i stumbled on your question today. This problem occurred with the Vaio VGN-FZ11E, after very very modest usage, no scratches or damage visible whatsoever.
There's one option out there:
"I found that if you hold down both left and right shift key at the same time (did this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem."
Quoted from here
If that doesn't work, seems to me the remark of Benwabnick seems to be the solution, as posted below.
579a389.jpg benwabnick
Rank: Guru sony.gifSony Expert
Rating: 89%, 428 votes
the contact underneath the shift key itself is starting to go bad. Its a common issue with sony laptops, the keys can wear out pretty quickly. You'll have to get another keyboard.
BR
Posted on Jul 20, 2009
  • 5603 Answers
SOURCE: Key board not working properly
The keybard probably has defective switches. They may have gotten wet or dirt in them. Not worth trying to fix. Buy new one...
They can be had off eBay for about $20 for brand new ones. Have a shop or competent person familiar with electronics work on it if you don''t feel capable.
The keyboard is USUALLY fairly easy to remove... USUALLY the second item to come off on a laptop when opening it.
Posted on Jan 29, 2010
Testimonial: "Hi Fredy 2 I think I will have to try other things as the keypad is clean. kind regards grannywag "
  • 56 Answers
SOURCE: hi, my sony vaio keyboard
usually to check if its working try to check if therea light on the keyboard
press capslock or NUm lock
if no go
Fn and F11
or FN and F6
in case nothing happens
Fn+ Numlock
ou also need to close the on screen keyboard ( if you open it )
hope it help thanks
Posted on May 22, 2011
Im using Blackberry 8520 Curve.. my problem is some of my keys in my keypad are not functioning anymore & some are really hard to press.. what i my supposed to do with these problems.. im not convinced...
usually when its hard to press the keys, there are dirts under them, ask your technicians to clean your phone using compressed air and if it don't work you need to replace the cover of your blackberry. purchasing a cover comes with a keypads.
Jun 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
Keypad locked - how do I unlock it? Operating System is Windows Vista.
You may need to press and hold the Fn key then press the Numlock key to unlock your keypad.
Please tell me how this goes. Thank you for using FixYa.
Dec 28, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
I have sony vaio but the av mode is not working and i have VGN-CS215J
Hi.
According to the information online, the issue might be due to the VAIO Launcher Application.
The VAIO Launcher Application is responsible for the functionality of the AV Mode keys.
Hence, it would be better to re-install the VAIO Launcher Application.
It is also recommended to install the Sony Shared Library before installing the VAIO Launcher Application.
I have mentioned all the links from which you can download the Sony Shared Library and the VAIO Launcher Application:
Sony Shared Library:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4236&os_id=34
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS215JW&upd_id=4403&os_id=34
Please click on the above links to download the Sony Shared Library and the VAIO Launcher Application.
Hope this helps.
Please feel free to contact for further information and assistance.
Nov 17, 2010 | Sony VAIO VGN-CS215J/W Notebook
Function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
May 15, 2010 | Sony VAIO VGN-FS840/W Notebook
SONY VAIO
Save Data if possible.
Use Restore System; Restore Computer to Factory "New" Condition.. Sont Vaios have a Key Prompt which you hold down while booting and the Replacement Software already on a Sector of the Hard Drive. Check THe Manuel for this OR CALL SONY CUSTOMER SERVICE AND JUST GIVE THEM THE MODEL NUMBER AND ASK THEM WHICH BUTTON YOU PUSH ETC TO RESTORE THE COMPUTER TO "FACTORY CONDITION"
Aug 19, 2009 | Sony VAIO VGN-CS118E/P NoteBook
I purchased Vaio VGN-ns21m keyboard dont function f1 f2... canc
i guess f1, f2, and all the function keys are given with added fn key in the left corner of the keypad. search for the blue icon with fn in the keypad. that should solve it. press fn along with the key you want to use.
Aug 12, 2009 | Sony VAIO VGN-N320E Notebook
Sony Ericsson K810i Keypad problem
i have the same problem as yours. the prob in my phone is that sometimes 1,3,6,# is not working and if i press repeatedly it works. i brought it to a technician and told me that i have to change the flex.
May 14, 2009 | Sony Ericsson K810i Blue Smartphone
Sony vaio keypad problems [ model VGN-A517M ]
Apr 23, 2009 | Sony PEGA KB11 Keyboard
System recovery #2 doesn't work
take out recov disks and do this to restore ur system to factory default all data will be wiped off from C:
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
tell me if it helped and rate me well or ask for more!
Apr 08, 2009 | Sony VAIO PCG-V505EC Notebook
Sony vaio motion eye
I have windows vista sony vaio vgn fe880e buying at america, but I dont have drivers of motion eye web camera
Jul 06, 2008 | Sony VAIO VGN-FE880E/H Notebook
Sony PEGA KB11 Keyboard Logo
108 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
