Question about Mad Dog Multimedia MD-5216CDR (20681870) CD-RW/DVD-ROM (Combo) Burner
Solution to power caliberation error in burnings softwares
I have experienced the exact same error on my system. However, i only happened with DVD's and not CD's. So I tried a few more DVD's, got the same error. Decided to gove it one more try, and the next disc worked! Burnt very slowly but it did eventually finish. The one after that worked as well.
I suspect it's the media (Discs) you are using may have some factory defects with them. Try another disc from the same pile, or eve better, buy a different brand and try those.
Hope that helps,
Cheers
Posted on Jul 15, 2009
2 Suggested Answers
  • 192 Answers
SOURCE: power caliberation error
Try uninstalling your burning software and then re-installing it.
Try uninstalling your drive, restart, and let Windows install it.
Download and update your Chipset drivers (recommended)
Update to the latest Windows Service Pack (recommended)
Uodate the drives Firmware version and internal drivers:
http://sony.storagesupport.com/product/112#drivers
Hope this solves your problem
Regards,
Tim
Posted on Dec 10, 2008
?why dos my compact plus test to high
it needs caliberation.caliberation solution is available in store.purchase it .Then run a caliberation
Jun 29, 2014 | Accu Chek Compact Plus Blood Glucose Meter
Trying to burn a dvd and i get this error please advise Module sfmmcx.cpp Line 2240 A medium error occurred. A Power Calibration Area error has occurred.
Your software and hardware are conflicting. Need exact problem for an exact answer. What type of burner, what type of program or software is trying to burn.
Feb 18, 2011 | Computers & Internet
Power caliberation error
  • Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
  • Try burning at lower speeds (Highly effective).
    Disable IMAPI Service (Work's in most cases):
    1. Launch Control Panel -> Administrative Tools -> Services .
    2. Browse for "IMAPI CD-Burning COM Service", Right-click on it and select properties.
    3. Chnage Startup Type to Disabled.
    5. Click Apply and Reboot.
  • Try updating or changing your CD\DVD burning software to the latest version.
  • Try upgrading your writer's firmware.
  • If all the above fails the problem is definitely related to hardware and not software, Go ahead and get your burner laser lens cleaned by a professional.
  • If all the above fails the drive's laser might have died and you need to get it replaced.
  • Best Of Luck, do post your results.
Jan 16, 2011 | Computers & Internet
What is the restore code in g five mobile
my mobile name is gfive. w520 screen touch problem and pen caliberation not successfull
Sep 21, 2010 | Locks & Locksmithing
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
Kodak esp 5 all in one printer, in the box where you read the info it says, error- Printhead missing, not installed correctly or has come loose. Checked all of that and it is still telling us this. What is...
switch off the printer again switch it on after 1 minute.. open the front access door , remove the ink cartridges and remove the printhead. reseat printhead properly until u hear a click sound. then again insert ink cartridges and wait for 2 minutes. go 2 menu and press caliberate printer.it will print a caliberation sheet. and now try to print ur doucment
Jun 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
Regards,
Tim
Aug 25, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Factory default disc on acer 4520G
If you have Nero of Power ISO installed you can right click the .iso file and there should be a command in the shortcut menu that states "burn with Nero" or burn iso with Power ISO, etc. this should apply to other disc burning software you have installed.
As you may know, .iso files are a compressed disc image file that contains the data layout for a complete CD or DVD. Most of the time, burning an iso image from first opening your disc burning software is more difficult but can be done by hunting through your software's menu commands.
Hope this has fixed ya!
Worldvet
May 16, 2008 | Computers & Internet
Mad Dog Multimedia MD-5216CDR (20681870) CD-RW/DVD-ROM (Combo) Burner Logo
67 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
