Question about Brother Office Equipment & Supplies
Said there was a paper jam. Cleared it all out. Still says there is a paper Jam, Cant find one and now it makes a trerrible noice on the left hand side where the printer head sits
  • kleckey Jul 14, 2009
    Is there anything i can try cause i need to use it now, what might be wrong with it
    What would be wrong with this printer. What could I check
  • 1,272 Answers
Hi, there is nothing more you can do on this printer.Get it checked by a printer specialist.
Posted on Jul 14, 2009
  • Anand Gupta
    Anand Gupta Jul 14, 2009
    When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
    1. Turn off the printer.
    2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
    3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
    4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
    5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.
    If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. *
    To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer. Preventing a printer paper jam As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer.
    However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring. * If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. * Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. *
    Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. * Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. * Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
    I hope this information allows you to resolve this issue.
    If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
    Regards
    Anand
How to clear jammed paper?
Locate the jam and carefully work to remove the jam. You don't want to tear the paper causing the jam as this will make things more difficult. You want to get the paper jam cleared by removing the paper as a whole.
Apr 07, 2018 | Office Equipment & Supplies
The display says clear original jam but there is no jam
You may need to check again. Even a tiny piece of paper left from when you cleared the jam will cause the printer to continue showing a jam. Make sure to also close any doors firmly.
Mar 08, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I've cleared to paper jam. Paper was not torn so
you have take the ink cantainer out and disconect the printer for one min then reconnect
May 27, 2010 | Dell 1700n Laser Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Paper jam. cleared jam but all lights are
hi,
you have to reset the device to make it detect the new status when unplugging didn't work. on resetting, the current status is detected again. this will remedy the situation.
cheers.
Jul 23, 2009 | Dell Office Equipment & Supplies
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Dell 3000CN Laser Priner
Removed the fuser unit and also removed the left hand side panel to access the gearing mechanism.
Manually rotated the gearing a number of times thru 360 degress. This appears to have cleared whatever was causing the printer to detect a paper jam although there was no obvious sign of bits of paper or even dust build up.
Dec 28, 2008 | Dell 3000cn Laser Printer
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
Carriage Jam
It is making a horrible loud clicking noice. The visual says carriage jam. There is no paper jam. What do I do?
Jul 28, 2008 | HP Office Equipment & Supplies
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
