Question about Stoves Ovens
Oven will not turn on - clock will not set Kleenmaid Scala
Seems that the Clock mechanism will not set (keeps flashing for Auto) and this seems to prevent oven from turning on. Cannot turn overn on. Tried everything in the manual to fix clock - no avail. Returned home from w/end to find the time (clock) flashing as though the power had gone off - but it hadn't.
SOURCE: fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Posted on May 19, 2008
SOURCE: Kleenmaid Scala wall oven and grill
manual available at www.kleenmaid.com/care
Posted on Feb 15, 2009
barkencoa
  • 3463 Answers
SOURCE: Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
  • 7 Answers
SOURCE: MY KLEENMAID SCALA OVEN/GRILLER
Try here: http://www.kleenmaid-appliances.com.au/ovens-care-kleenmaid.aspx
Posted on Apr 14, 2011
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
Kleenmaid scala oven how to reset the timer buttons oven keeps
Press the cook and finish cook buttons at the same and +and- button to advance the time. They look like a casserole dish and a casserole dish with a cross through it
Apr 13, 2010 | Ovens
Apr 06, 2010 | Ovens
I need the user manual for a Kleenmaid Scala oven
clock is on auto o.oo and can not change it
Dec 07, 2009 | Ovens
Thanks.
Jul 19, 2009 | Ovens
Cannot set the time on kleenmaid scala oven
My kleenmaid scala oven clock will not set and I can't turn oven on. I have re set the power etc. Do I need a repair man?
May 14, 2009 | Ovens
Jan 17, 2009 | Ovens
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
244 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
