Question about Microsoft Windows XP Home Edition
Drvstore is blue
I used the above solution but it is still blue
    Sergeant:
  • 336 Answers
What is wrong??
Thanks
Ryan Frame
Creative Energy Associates Technical Center
Posted on Jul 28, 2009
Is vitamol v10 the same spec as magura blue blood
All the above answers saying to use a DOT or other fluids are wrong.
Never use DOT-3 or DOT-4 based fluid in a system equipped for Magura's Blue Blood or Vitamol V10 mineral oil. Using DOT-3/DOT-4 fluids will likely cause seals to fail in your clutch or brake cylinders.
To answer your question: yes, I believe both Blue Blood and Vitamol V10 products are equivalent SAE10 weight mineral oil.
Jan 05, 2013 | Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1995
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1720
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Distributor
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector)
Parking Lights: Red/Black - (+) Above Fuse Panel
Head Lamp: Red/White - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue - Steering Column (Relay Required)
Windows UP: LF=Red/Blue RF=Blue/Yellow
Windows DOWM: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This...
1994
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Hood Pin: n/a
NOTES: - none -
CRUISE CONTROL:
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
How do i use the blue tooth function. it is above he f3 key.
is it above the f3 key or on the F3 Key in blue.
if it's
on the F3 Key in blue then hold down the FN key & press it again, the FN Key is at the bottom left of the keyboard.when pressed all the blue/white SYMbols can be put uo
Jun 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1992 Honda Civic This...
1992
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
Parking Lights: Red/Black - (+) Above Fus Panel (White Connector)
Hood Pin: n/a
Factory Disarm: Disarms with Unlock
Door Trigger: Green/Red - (-) Driver's Running board
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
Windows DOWN: LF=Red/Yellow RF=Blue/Green
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, Grey connector.
NOTES: 4000PPM
Tip
Changing brake fluid
ATE currently produces and markets two DOT4 brake fluids with the identical specifications: * Dry boiling point of 536 degrees Farenheit which is 122 degrees Farenheit above DOT4 Specifications, which is Super Racing Blue * Wet boiling point of 392 degrees Farenheit which is 113 degrees Farenheit above DOT4 Specifications, which is Original Brake Fluid TVP 200. Other than packaging, the primary difference between the two is color. The Blue is blue in color and the 200 is clear or light amber in color. This facilitates flushing and changing fluid such that if used alternately, the flusher will know that the job is done correctly when the color change is complete.
on May 19, 2008 | 2007 BMW 760Li Sedan
I am trying to install a 42" ceiling suspended fan .. just making sure the blue(1) and black(2) wires go together and then the green goes to the bare ground wire coming from the box.
If you are not using a seperate switch to control the fan the blue and black go together and the white goes to white and the green goes to green. The blue wire is the fan power wire and the black is the light power wire if you are just using the switch on the fan to control the fan speed then the above configuration is the way it should be wired.
Jan 19, 2010 | Aloha Housewares (93645) Ceiling Fan
Trailer Lighting Kit
Do u have a 4,5,6,or 7 way (wire) system? If it's 4 way it allows basic hookup for 3 lighting functions:
GREEN is right turn signal and stop light, YELLOW is left turn signal and stop light, BROWN is license, and side marker lights, WHITE is ground.
5way is same as above, but adds a BLUE wire for brake signal or aux. power. Its used on pop up campers, utility and boat trailers.
6way (rectangle plug) green=right turn signal, yellow=left turn signal, brown=taillight, white=ground, red and blue can be used for brake control or auxilary. Used on small motorcycle trailers, snowmobile trailers, utility trailers.
6way Round Plug, same as above, but blue is electric brakes, and black (sometimes red,) 12v; note:sometimes red/black need to be reversed w/ blue to suit the trailer.
7way adds an additional pin at plug in for 12volt power or back up lights. Whoa! hope that answers your question w/out confusing u. Let me know if u need more info.
Oct 27, 2008 | 1997 Mitsubishi Montero Sport
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Microsoft Windows XP Home Edition Logo
478 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
