Question about Acer Aspire One Netbook 8.9" Notebook
SCREEN RESOLUTION RESET
The screen resolution is set too high and cannot be displayed so all that I see is a black screen, how do I reset the defaults on the screen resolution? Thank you
  • 716 Answers
When Setting The Screen Resolution There is a 30 second wait period where you have to click ok for the setting to take permanent effect. If you could not see anything it should have returned to normal within the time limit and or is not saved and can be returned to normal by reseting the computer via the power button.
Hope This Helps.
Sincerely,
Michael Scott
Posted on Jul 14, 2009
Tried to enlarge the screen and screen went black and now showing this! I turned it off and hit F8! It came on I pressed safe mode! I tried to get on Internet and it locked up again ! Back to this scr
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor.
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
Oct 20, 2012 | Computers & Internet
Tip
XBOX 360 Screen Resolution Reset
Due to the fact I change the TV I use my XBOX 360 on sometimes, I find I connect the console and its output is set higher or to an incompatable resolution that my TV can display. If this has happend to you you need to reset the resolution to default, here's how you do it without needing to see the dashboard:
  1. Remove any discs from the disc tray.
  2. Turn the console off.
  3. Using the player 1 controller turn the console on using the big X guide button.
  4. As the console starts, press and hold the Y button and pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console.
Job done!
on Mar 31, 2010 | Video Game Consoles & Games
I set my resolution too high on my VXL Itona C42 thinclient. Now i'm stuck with no display. how do i get it back to normal?
To Reset the display to 640 x 480 press :- CTRL+ALT+SHIFT+F5
To reset the terminal to factory defaults press :- CTRL+ALT+SHIFT+F9
itona, vxl, reset, factory defaults, screen resolution, display
Feb 14, 2012 | Vixel VXL Itona TC2341CE Thin Client ...
Computer monitor out of range is being flashed on screen
Monitor is not recognizing the resolution settings that are currently set on the computer.
It is probably sett too high.
You will have to lower the computer resolution.
If it is a laptop, you should be able to do this using the laptops screen.
If it is a desktop computer, you either have to use a different screen to reset the resolution.
or
Sometimes restarting the computer while the screen is on will reset the video.
If that doesn't work, try starting the computer in safe mode by tapping the F8 key while it is being started. This will keep the resolution low enough to see it on the monitor and you can adjust the resolution there in the display properties
Oct 19, 2010 | E-Machines eMachines Monitor E15T4
Black border either side of the screen
hi this could be the resolution settings, try changing it to a different resolution, till you get it to fit hope this helps
Sep 04, 2010 | Computers & Internet
1. Had some problems recently with my lap top.
The action you took to fix your computer by resetting it has reset the screen resolution to what sounds like the XP default.
To adjust the screen resolution follow this set of instructions-
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
//javaftper
Jul 31, 2010 | Microsoft Windows XP Home Edition
I plugged my monitor into another computer i have and the start up screen pops up but then it goes black and says " input not supported"
You need to set the video output of the PC to the native resolution of your monitor: 1440 x 900 @60Hz. You are getting the meaasage because the resolution is too high for the monitor to display.
Mar 16, 2010 | Acer X193W LCD Monitor
Everything on the screen is enlarged?
You should be able to reset you screen resolution by clicking on Display inside the control panel. Go to the Settings tab once the display properties window opens and look for the screen resolution area that allows you to adjust the resolution. If its set at the low end, move it over to the high end and press Apply to test out the new sizing
Mar 26, 2009 | HP Pavilion dv6000z Notebook
WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
When I set My LG PC monitor to High resolution setting from 16 bit to 32 bit, its not supporting that resolution and start blinking only. I am unable to find , how to reset it to default.
Restart your PC and press F8 before windows bootup and select VGA Mode so that when your windows finish loading windows in a VGA mode you can easily choose the Display setting you like. Remember to keep your Screen refresh rate not so high which can permanently damage your monitor.
Dec 02, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
