Question about 2wire HomePortal 1000 Router
Intermittent ,the 3 lights go on then the first will go red and the 2 below becomes unlit.computer too slow when on.
  • 60 Answers
You need a firmware upgrade for the router.
Posted on Jul 16, 2009
Why would using the turn signals make the engine misfire
The common element to me is the battery - bad voltage can upset the computer.
Jan 16, 2013 | 2003 Chevrolet Impala
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
How do I realign the sensors?
Both sensors will have their green led lights lit (on) when aligned. When not aligned only one sensor will be lit.
Make sure both sensors' lens are clean.
If still not aligned loosen the lit sensor from its mounting bracket using the proper tool, but most LiftMasters have a wing nut mounting for the sensors.
Aim the free sensor in the direction of the unlit one and look for its led to light. If necessary, using a screw driver remove the staples securing the sensor wiring enough to physically place the sensors eye ball to eye ball looking for the unlit sensor to light. If the unlit sensor still won't light then there is a broken or pinched wires some where between the unlit sensor and the garage door opener.
Jul 22, 2011 | liftmaster Garage Door 1/2 Hp
I have a 274V outlet w/ switch for my garbage disposal. I hooked it up and used a MICRONTA 3-prong circuit tester on the power outlet to make sure it was wired correctly and it showed that the right LED...
you are missing something
you describe 3 led lights --2 green and one unlit then you go on about a red led light
suggest that you get in an accredited electrician to check the circuit
it is possible that you are testing with the wring tester
Mar 27, 2017 | Cooper Wiring Devices 274V-BOX DECORATOR...
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
My screen has gona black, or at least unlit, i can
was screen redish or pinkish earlier when was still working when you turned it on?
If so that means ccfl lamp for your laptop screen is bad, need to replace it
Dec 29, 2009 | Toshiba Computers & Internet
3 red lights
oh no!its the RROD..red ring of death..u will need a replacement console..do call microsoft for a new one..i got three such!hope u get urs soon!!
Nov 02, 2008 | Microsoft Xbox 360 Console
Open Questions:
2wire HomePortal 1000 Router Logo
63 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
