MAG 780 lcd Monitor
Used to work great.. but then it started taking longer and longer to get out of sleep mode and turn on. now it wont turn on at all, the green light just goes on and off. and no picture just a blank screen
  • superstone79 Jul 14, 2009
    i tried both of those.. but didn't work.. and now the screen flashes occasionally
  • 130 Answers
It's risky... But try reinstalling your, Graphics Driver, Sleep mode is used occasionly if you use it too often your screen will eventualy wear away. If that still don't work. Try reinstalling Windows.
Posted on Jul 14, 2009
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
My monitor is taking a really long time to turn on
The problem is with your Harddisk. Try removing and reconnecting it again. Run the scan disk utility.
Jun 19, 2009 | Mag Innovision 19" LCD Flat-Panel Monitor...
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
Jan 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace.
Thank you,
Mar 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
MONITOR
change the pc to stop it from going to sleep
Mar 03, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG monitor is all white
please change your ram immeditately or monitor itself because the life of monitor has been came to an end...
Dec 31, 2007 | Mag Innovision InnoVision LT765 17" Flat...
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
