Question about Danby DKC645BLS Compact Beverage Cooler
Temperature at below zero; temperture control not working
Hi, my kegorator is now maintaining a temperature of below zero, and I cannot adjust the temperature with the control panel (the buttons are not functioning at all). These problems seem to have occured at the same time. Can anyone help? Thanks!!!
Jim
  • 52 Answers
Sound's like your cold control is bad.
Posted on Jul 14, 2009
Dyson fan heater keeps shutting off
Hi Deb, it's Jack at Dyson.
If your AM04 fan heater runs for a few moments then shuts off, this is likely to be because the target temperature you've selected (shown on the LED display on the base of the machine) is lower than the ambient room temperature. The intelligent thermostat is engineered to ensure the machine will only run as needed to maintain the target temperature you've chosen.
Using the remote, or the controls on the base, to raise the target temperature by a few degrees should resolve the issue. I've included our Getting started guide below which shows how to adjust the temperature.
If you would like some further help from our experts after you've given this a try, please call 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 06, 2013 | Dyson AM04 Table Fan/Heater
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    I need a adjust temperture control board
    Are you asking to adjust the temperature control board, or are you saying you just need a temperature control board?
    Nov 09, 2010 | GE Americana A4425GDTWW Side by Side...
    Temperature does not go below 59 deg. refrigerator side.
    Auto Damper models, The Auto Damper model refrigerator has
    two controls and both have capillary sensing.
    The Auto Damper controls the fresh
    food temperature and the Freezer Temperature
    Control guides the freezer temperature.
    The fresh food compartment temperature
    is maintained by a damper assembly located
    at the back of the temperature control
    housing. Changes in air temperature
    cause the damper door to open and close.
    A control rod and gear connect the fresh
    food control knob to the damper control.
    Turning the fresh food control knob to the
    COLDEST position increases the flow of
    freezer air into the fresh food section. The
    freezer compartment temperature control
    warms at a faster rate and cools at a slower
    rate, increasing the compressor run time
    necessary to maintain a satisfied freezer
    temperature control.
    Turning the fresh food control knob to a
    WARMER setting decreases the flow of
    chilled air into the fresh food section. The
    warms at a slower rate and cools at a faster
    rate, decreasing the compressor run time
    It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
    Temp not going below zero
    If that is 0 F it is probably the default temperture and is ok. Above 0 food detoriates quicker and below you get freezer burn faster.
    If the controls are locked to that temperature it usually involves holding the button for 3 to 5 seconds to unlock and then adjust. (That is on modern frost free freezers in general)
    May 04, 2009 | Bosch Freezers
    Best temperture to keep up right freezer and a different refrigerator
    Freezer temperature for storage depends on the type of product you are putting into it. Ice Cream as an example must be kept below zero °F as also with bread dough type products. Refrigerator temperatures are best kept below 41°F.
    Jun 30, 2008 | Refrigerators
    Fridge freezer
    Check your settings for the temperature controls. Freezer may be set to warm (IE #1) set it mid point. Also set the refrigerator at mid point and go from there to adjust each to maintain the temperature balances.
    May 31, 2008 | Freezers
    Stove won't go below 170
    The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
    May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Cooler wont cool below 48 degrees.
    Keep a thermometer handy. (adjust temperature control knob accordingly)
    Periodically monitor temperatures inside your cooler. (adjust as necessary)
    Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
    The temperature of the refrigerator compartment is
    controlled by adjusting/setting the thermostat control
    knob, located on the ceiling of the refrigerator
    cabinet.
    To start the refrigerator, and achieve maximum
    cooling quickly;
    • Turn the temperature control knob (using a coin
    or screwdriver) clockwise to the furthest
    (maximum) setting on the darker blue section of
    the graduated control dial.
    • Allow the refrigerator to run at this setting for 3~4
    hours.
    • When maximum cooling is achieved, turn back
    the temperature control knob setting to the 2:00
    o'clock position on the graduated blue control
    dial.
    • Correct cooling temperature is a key factor to
    consider in storing and dispensing draught beer.
    • Optimum temperature for serving draught beer is
    between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
    • To maintain temperatures ranging between
    34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
    thermostat knob be positioned at the "2:00
    o'clock" setting on the graduated blue control dial.
    • To turn off the refrigerator, (no cooling) rotate the
    control knob to the "0" position.
    Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
    Danby DKC645BLS Compact Beverage Cooler Logo
    360 people viewed this question
    Top Danby Refrigerators Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
